Overheating
Old 04-03-2008, 10:03 PM   #1
Overheating
Just had my water pump replaced and now my truck is overheating at idle. when i drive it it gets up to about 240 and then drops to about 140 and starts heating up again
We let it idle and the temp never dropped, backed down my driveway and the temps dropped within 100 feet of moving.. why god why?
i replaced that thermostat about 2,000 miles ago
Old 04-03-2008, 10:35 PM   #2
getting shit done
laydout97's Avatar
Re: Overheating
sounds like low coolant or an air pocket in the colling system. did you bleed the cooling system after the water pump was installed?
Old 04-04-2008, 12:05 AM   #3
Re: Overheating
it was replaced at a shop so i would have to assume so
Old 04-04-2008, 12:06 AM   #4
Stepsides are cool
xxannihilationx's Avatar
Re: Overheating
i would take it back and have them look at it
Old 04-04-2008, 12:11 AM   #5
getting shit done
laydout97's Avatar
Re: Overheating
Old 04-04-2008, 12:13 AM   #6
Molon Labe
BudRacing's Avatar
Re: Overheating
Or just check your coolant level and top it off with water. It could save you some time and dealing with the grease monkeys at the garage.
Old 04-04-2008, 12:24 AM   #7
Stepsides are cool
Re: Overheating
but if that doesnt work you going to have to bleed the coolant system and my as well let them do it and save yourself some work
Old 04-04-2008, 01:51 AM   #8
Re: Overheating
Just open the cap when it's cold and see if you can add water. Big time saver and they won't find "something else" to fix.
Old 04-04-2008, 08:30 AM   #9
Re: Overheating
its radiator is topped off and i even put more into the engine coolant reservoir, its not leaking out anywhere and there is no coolant in the oil just an FYI if those were your next questions.
Old 04-04-2008, 09:59 AM   #10
Molon Labe
BudRacing's Avatar
Re: Overheating
Ok, then let the shop handle it.
Old 04-04-2008, 01:34 PM   #11
bling bling like WHOA
xtreme03blzr's Avatar
Re: Overheating
Take the cap off the rad, run the engine for awhile. if there is air it will burp itself.
Page generated in 0.59236 seconds with 31 queries
[Output: 72.56 Kb. compressed to 67.76 Kb. by saving 4.80 Kb. (6.62%)]
