oil filter lines
Old 04-11-2009, 03:59 PM   #1
oil filter lines
ok so i search all the forums i know of and found nothing about the oil filter line removal . i found a lot about replacing and removing the cooler lines but nothing about the filter lines. the ones i am talking about if you don't understand are the ones from the oil pan to the oil filter. i can get the bolt off of the lines that is attached to the filter part but cant get to the bolt that attaches them to the engine/oil pan. how do i get them off? thanks
Old 04-12-2009, 08:55 AM   #2
Re: oil filter lines
ok so i called my goodyear/gemini repair shop and they said they dont have a clue what i was talking about and dont do it. but some one told me that i should get a 2X4 and put that on the oil pan and then get a jack and jack it up enough to get to the lines. is that is ? can you just jack up the motor and not hurt the motor mounts? any input would be nice. thanks so much!
Old 04-12-2009, 09:19 AM   #3
workin it !
S10dude's Avatar
yup don't understand.....
Old 04-12-2009, 03:55 PM   #4
so basically i need some one to tell me how to replace the oil filter lines. i cant get to the bolt that is connected to the engine. it is in a place you cant get to.thanks
Page generated in 0.56124 seconds with 31 queries
[Output: 49.61 Kb. compressed to 47.27 Kb. by saving 2.34 Kb. (4.72%)]
