oil cooler lines
was wondering if many have had prob with the oil cooler lines on the 2nd gen jimmy's and blazer? i came up with a good fix for the prob using AN fittings works realy well and looks kinda cool under ther now
I'm probably drunk.
Re: oil cooler lines
what do you do??
CHANGE YOUR EMAIL ADDRESS
Why post about a sollution and then say nothing about it... lamo
sorry about that haven't been on the comp much these past days but i had gotten my hands on some old 1/2 Aircraft lines much better quality then the GM ones and used AN fittings that came on the ends of the lines, cut and flair the alumimum protion of the line and used AN callers and unions. this was a rather costly affair cause the an unions are around 20buks each but in the end turned out to be about the same price as it would be to replace the hole thing but now have a quality set up sitting under. i tried to put some pics to show but can't seem to get it work for me
TO PUNISH & ENSLAVE
madme,
If you would like to get the pictures up PM me and I will help you with that. ~M~ |
