Odd consistant hum (wo wo wo) tire sound - 00 Bravada
Old 04-07-2009, 05:48 PM   #1
I just started noticing an odd sound coming from the driver side front wheel. First off it's an 00 Bravada and the tires should be good (were fine last time I checked) and I JUST got it inspected so I'm guessing the wheel bearing is ok.
Basically the sound is constant, it doesn't change w/ speed or if you are going straight or turning. Wo wo wo is the sound (i know it sounds dumb).
Any ideas? When I got it inspected, I had to replace the upper ball joint on the same side but the shop said everything else was fine.
Thanks
Old 04-08-2009, 02:11 PM   #2
Re: Odd consistant hum (wo wo wo) tire sound - 00 Bravada
No one? I think I'm starting to feel it slightly now. But it still doesn't change w/ speed or steering. I'm hoping to swap the wheels by friday, so hopefully I will know if it's the wheel or suspension.
Old 04-08-2009, 02:26 PM   #3
Founding member of DA
pack of q tips's Avatar
could be a wheel hub hard to diangnose over a computer
Old 04-08-2009, 02:27 PM   #4
I'm a sarcastic ass.
Bootylicious's Avatar
you sure its coming from the wheels? if it doesnt change with speed or steering sounds like the problem could be elsewhere.....sorry im not much help man.
Old 04-08-2009, 02:37 PM   #5
Slap my meat on your pita
GeorgesBlazah's Avatar
Check for play in the bearings
Old 04-08-2009, 04:36 PM   #6
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
Id think the hub bearing as well.
Old 04-08-2009, 05:42 PM   #7
Giggity Giggity
Woody22's Avatar
its most def the muffler bearing.
Old 04-08-2009, 11:01 PM   #8
K Dawg ONE's Avatar
I agree.
Need to run to Autozone and pick up some cross drilled/slotted brake lines. Be sure to top up the headlight blinker fluid too! Autozone also has cans of compression on sale right now too i think (15% off or something like that)
Old 04-09-2009, 02:59 PM   #9
Front wheel hub.
Old 04-10-2009, 12:38 PM   #10
rotate your tires if the sound stays then its your hubs or your rotors are warped... you could check for excessive heat coing from the hubs or rotors but getting a temp gun and pointing it at each componant after a long drive... you could even check your tires this way... if one is hotter then all the others by alot then something is going on inside... did they do an alightment after they replaced the upper ball joint... you can also jack the truck up and shake the tire around... if there is play side to side then its a tie rod... if its top to bottm then its the hub or ball joints... it alll depends on how it moves and if and where the heat comes from
Old 04-10-2009, 12:43 PM   #11
96S10BlazerGuy's Avatar
sounds like a wheel bearing
Old 04-10-2009, 12:44 PM   #12
where's my chippy?
lee-mill's Avatar
Old 04-10-2009, 08:47 PM   #13
takes 2 balls in our game
s10-den's Avatar
wheel bearing.Mine just did the same thing...
Old 04-14-2009, 04:03 AM   #14
First off, thanks for the comments, I hadn't realized people had replied since I never received a noticed via email.
But honestly I still don't think it's the bearing because the sound doesn't change when you turn. And I have dealt w/ wheel bearings before (not on the bravada) and this doesn't sound anything like a bearing. And I haven't swapped the wheels yet but that is the next thing I'm going to do.
And I did the ball joint swap but an alignment shouldn't be needed. But also, If I remember correctly, I think the sound started before I did the ball joint but I'm not 100% sure on that.
It almost seems like you can hear the sound when the tires are cold but gets lighter/softer after driving for awhile. And I was incorrect before, the sound does change w/ the speed of the car/wheel!
Oh and thanks to the few retards that don't have anything useful to say!
Old 04-14-2009, 07:05 PM   #15
forum idiot
orangesonoma's Avatar
best way to tell is to ack up the truck and move the wheel around and see where the play is...mine was doing the same thing..and i replaced the wheel hubs and all was good
Old 04-15-2009, 12:20 AM   #16
Ya that is the plan, just really hoping it's not the hub because I don't want to spend the $200+ just yet... But most likely I will in the end...
Old 04-15-2009, 09:53 PM   #17
s10-den's Avatar
Hell, I thought at first mine was the tires, bought new ones and drove down the road and was pissed, went home and replaced the hub bearings and rode just like new again.
Old 04-15-2009, 10:00 PM   #18
forum idiot
they are not that bad to replace yourself..i did mine with hand tools a a small jack in under 3 hours for both sides..and that was with a lunch break and trips to the parts store..
Old 04-16-2009, 12:31 AM   #19
Ya I did an oil change today and swapped the front tires, no change... So I'm going to replace the hub next week.
Ya I'm not that worried about doing it, it seemed pretty simple. I just hate wasting the money/time right now since I have a motorcycle/chopper project I'm dying to finish by next month. Gotta have your priorities ya know
Old 04-23-2009, 07:29 AM   #20
So next question guys, since the noise isn't changing when I turn the wheel, how am I supposed to know which hub to change? I checked for play and didn't really feel any from either wheel...
It sounds like and feels like it's coming from the DS but not 100% sure. Any other way of being sure? And no I don't want change both right this second...
Page generated in 0.68796 seconds with 31 queries
[Output: 105.22 Kb. compressed to 97.24 Kb. by saving 7.98 Kb. (7.59%)]
