O2 sensors posibly bad?
Old 10-07-2008, 09:21 AM   #1
I have a 95 Blazer with a 4.3 CPI. The SES light is on and the code reader says the EGR is the culprit. Replacing the EGR valve didn't help at all, neither did any attempts at cleaning. The thing runs rich and surges when you try to hold a constant speed. I suspect the O2 sensors but they don't show bad in diagnostics.
Ideas?
Old 10-07-2008, 09:41 AM   #2
Local Tech
ls1s10onair's Avatar
Re: O2 sensors posibly bad?
what was the egr code exactly? if it was low flow, that can be caused by no backpressure in the exhaust (hollow cat, straight-pipe, glasspack) also, the port for the egr could be clogged up with carbon
Old 10-11-2008, 09:52 AM   #3
It was low flow and a new muffler fixed the problem. Thanks.
The SES stays off now but the vehicle has high readings on the measured pollution items, consistantly about 50% more than allowed.
Old 10-11-2008, 10:09 AM   #4
Local Tech
i take it you failed inspection....? list what each reading was and the allowances, im sure i can help
Old 10-11-2008, 10:49 AM   #5
HC Reads 3.2356 Allowed 2.0
CO Reads 31.0024 Allowed 20.0
NOx Reads 6.03 Allowed 4.0
Old 10-19-2008, 04:49 PM   #6
Registered (Ab) User
Yogi's Avatar
Does it still have the cat? If so, has the cat been punched out or damaged or modified in any way?
Old 10-20-2008, 08:45 AM   #7
Cat still there, hasn't been touched. About 160 K on it
Old 10-20-2008, 10:41 AM   #8
Yogi's Avatar
I would open the intake manifold and check for leaks. The CPI is notorious for having leaky fuel pressure reg. and leaky fuel lines. Check this thread.
Old 10-27-2008, 08:04 PM   #9
OK.
To this point I've had the cat replaced - all the material inside had blown out - it was hollow. This got it past the emissions test.
The EGR code 0401 (insuffient flow) started coming on again. Pulled the upper part of the manifold off and found the EGR port plugged solid. Chipped it open, ran a brass brush in it and blew it out.
The regulator on the CPI was leaking so that got replaced.
EGR light stays off now but the engine (sometimes) surges pretty bad at 55 or so (it did this a bit before but I don't think it was as bad). I'm going to pull the top off again to check for fuel leaks this weekend but was wondering if there's anything else that causes this.
Old 10-28-2008, 11:57 AM   #10
Yogi's Avatar
OK.
When you take the top of the intake off, you might also want to pull the distributor and check the gear for excessive wear. Click here for more info.
Page generated in 0.57716 seconds with 31 queries
[Output: 70.64 Kb. compressed to 66.20 Kb. by saving 4.44 Kb. (6.28%)]
