noise while turning
Old 04-23-2006, 11:59 AM   #1
goblue9976's Avatar
noise while turning
Sorry if this has already been answered.
When I turn the wheel almost full either direction, it makes a nasty grinding noise. I cant tell where it is coming from, but it is only when I turn full lock. Is this a serious problem?
Old 04-23-2006, 06:55 PM   #2
95 Beater with a heater.
Re: noise while turning
I hope someone can answer this because my 95 Blazer makes a bad noise when I'm turning but only when backing up? it's not in the trans but from the front end, I only hear it when I'm backing out sharpe from my driveway in either direction?
Old 04-23-2006, 10:24 PM   #3
goblue9976's Avatar
my friend's blazer (just was with him today, its a 98) does it to...
Old 04-24-2006, 07:45 PM   #4
goblue9976's Avatar
anyone?
Old 04-24-2006, 08:55 PM   #5
shefsdime94's Avatar
its hard to make a guess without hearing a noise but my friend had a problem like that and is it tougher to turn the wheel? if it is then it might be your power steering.. check fluids and such.. could be your powering steering pump but if its not then no clue.. gl w/ it
Old 04-24-2006, 09:10 PM   #6
goblue9976's Avatar
i dont think that its harder to turn...if it is, it is ever slight. The noise is a grinding noise (metal on metal) and it is only at full lock turns (backing out of a parkingspot)
Old 04-24-2006, 09:21 PM   #7
Molon Labe
BudRacing's Avatar
I have a good knocking noise when I turn it nearly to full lock. I'm not sure what it is either.
Old 04-24-2006, 09:25 PM   #8
tuckin' fx4
zachmartin83's Avatar
i get like a little whine when im backing out at full lock
Page generated in 0.58356 seconds with 31 queries
[Output: 62.17 Kb. compressed to 58.41 Kb. by saving 3.76 Kb. (6.04%)]
