NO Reverse, NO 2nd gear!!! HELP
Old 05-19-2008, 09:06 PM   #1
alright, I have a 2001 Blazer, 4.3l, 4L60E trans, 4WD.... I hooked up my tech 2 and have no codes... looked at the data while driving... when you drive, the tech 2 shows current gear as 1st, then shows current gear as 2nd, but vehicle does not shift... it revs to 4k then shifts into 3rd... 4th engages as normal... also I have no reverse. the PRNDL switch operates just fine... the shift time for the shifts are as follows:
1-2 0.00 sec
2-3 0.20 sec
3-4 0.20 sec
what are the thoughts!!!
need help, please post soon.
Old 05-20-2008, 09:19 PM   #2
Registered (Ab) User
Yogi's Avatar
Re: NO Reverse, NO 2nd gear!!! HELP
Try posting in the tranny/rearend section. Might get a better response.
Old 05-20-2008, 10:08 PM   #3
ok, moved as requested...
Old 05-21-2008, 12:33 PM   #4
Goran's Avatar
i had similar issues...
ended up being my torque convertor solenoid...
luckily it was still under warranty...
Old 05-22-2008, 02:14 AM   #5
found a broken sun shell when I took the trans apart
Old 05-22-2008, 10:50 AM   #6
Yogi's Avatar
Glad to see that you found the problem!
Old 05-22-2008, 11:27 AM   #7
jhankinson's Avatar
Yeah the sun gear is KNOWN to fail in these trans...that is what cause the no Rev and no 2nd
Old 06-08-2008, 01:10 AM   #8
Evil_s10's Avatar
that's what mine did, when sun gear goes out, no 2nd 4th and reverse.
Old 06-09-2008, 11:54 PM   #9
WalkGood's Avatar
Yeah the sun shell gear is a cheapo made $35 part that causes a total rebuild most of the time when it strips.
Page generated in 0.56762 seconds with 31 queries
[Output: 65.24 Kb. compressed to 61.15 Kb. by saving 4.09 Kb. (6.27%)]
