need washer hose routing info
Well, I'm slowly getting a 2001 Jimmy back on the road that I picked up cheap. Found out today that the washer hose going back to the rear hatch is leaking and through a siphon effect it empties every bit of fluid I put in the washer reservoir.
I found where I think the leak is coming from. The fluid is dripping from the left rear just above where the evap canister is. If I pull out all the tools and tool panel I can see the line going down, but I don't know how to get to the hose. Does anyone have a simple way to get to the hose or do you know if it can be pulled through from somewhere else so I can patch and get this working again? Should be a simple fix, but it appears this rubbed somewhere I can't get to. |
Re: need washer hose routing info
2dr or 4 dr?
Duh, it's a 4dr. I can reach the hose going down behind/next to the rear taillight assembly, but I lose it as it heads down lower. I'm beginning to think I'll need to remove the panels no matter what.
you will have to remove the lower panels and the carpet. I know on my 2dr it was in a plastic tray and went under the carpet and into the tailgate. I had to remove all 4 seats and both carpets to get rid of it.
Considering the date on your posting, you most likely already figured this out...
Anyway, UNDER the pad - of the carpet - of the back bed, you will find a crappy little plastic nipple connector similar to the 1/4" ones used for underground sprinkler accessories. This flows into to a an 's' connector (also cheap plastic) via a rubber hose sleeve, that runs UNDER the rear sill cover just in front of the fold-down tailgate. Remove the rear sill cover - most likey you will find the 's' disconnected, and the hose from up front siphioning into the channel (it runs out the drip hole on either end). I added a 'mini' hose clamp to mine, since it seems to be another GM 'oops' in Blazers... Good Luck - DJG ![]() |
Yea, figured it out maybe 2 months ago now. I found a 90* connector popped loose. What got me was how tight everything was and even though I popped the connector back together, it was a really tight fit and I'm sure it will pop out again sometime this winter when it's like 5* outside.
