Need help i have pics
A friend of mine gave me some drilled and slotted rotors for a blazer and before i go and buy a blazer i would like some input on which years these go on and what specs of a blazer/jimmy i need. i appreciate all of your guys help.
I just need to know which picture are the rear brakes and the front brakes and what years of the blazers they go with. ![]() ![]() |
got me some 20s
Re: Need help i have pics
pretty sure from lookin, the top ones are for front brakes and thats all i can answer lol
getting shit done
top- front
bottom- rear |
does anyone know what years of blazers/jimmy's these rotors apply to?
so someone gives you brakes and you go buy a truck to fit them? i wouldnt use the fact that you have some rotors as a deciding factor in getting a vehicle.
looks like a 2wd with disc in the rear, mine is an auto and has drums in the back, so i bet its for a 5 speed w/posi. just bring them with you and take 2 wheels off, it will take ten mins. plus it doesnt hurt to check those things when buying a vehicle, but who does that anyways. go to an autoparts store and ask to see if they can line what they have up with yours. |
CDN 2WD 2Gen 4-Door!
I cant see the pics, but, they could be for a 4wd....thicker ones with the vents would be front...thin solid ones would be rear (though the pics are blocked at work)
The Dreamsicle
can you take some pictures of the backsides of them?
Here are pics of the sides and of the back sides of the rotors
fronts ![]() ![]() rears ![]() ![]() |
better give them to me..so you dont have to worry what they fit on
i might have to let get them from me,
my company is going through some hard times and i think i might get laid off but anyways they are some nice rotors they feel durable and not cheap. i was surprised my friend just gave them to me. |
forum idiot
they are for a 2wd truck...with disc in the back...
Needs a clutch... BAD!
no there for a 2wd truck with drum in the rear... lol:P... wow yes rear rotors... i think we got that covered...
The rear disks sure aren't from a 4wd, at least not an 01 model. They are quite a bit smaller than my 4wd ones.
It's a Blue thing...
I give you fitty dolla.
Registered (Ab) User
Well I'm sure that they will not fit a '98+. The '98s have sealed hubs with non replaceable bearings. Those fronts have the old replaceable tapered roller bearing races, so they are somewhere pre-'98. So it would fit the years that they added discs to the rears but b4 they went to sealed front hubs.
forum idiot
The Dreamsicle
that sucks that the fronts are pre 98. i sent him a pm yesterday about buying them. nevermind now.
i dont think they are pre-98 as my 02 s10 has clean and repack front wheel bearings as a 35k or 50k service.
The Dreamsicle
Good Bye SonomaST
the fronts are for a 82-04 s10, and 83ish-97 blazers. the rears are for rear wheel disc brakes, not sure 2wd or 4wd. my 2wd rear has ported rear rotors
my buddies 4wd 98 blazer has drum inside disc in the rear. if it matters its 2 door 5 speed...
The Dreamsicle
#24 |
obviously, but im stating that its probably for a 4wd bc of the drum
#25 |
The Dreamsicle
im sorry but i still dont know what you're talking about exactly. my rear discs are the exact same way.
#26 |
Wannabe Dragger
#27 |
so then blazers get the disc/drum and s10's get the drum.
#28 |
The Dreamsicle
umm yesss... the blazers, starting a certain year- maybe '98. have 4 wheel disc brakes. the ebrake on these trucks operates like a drum brake.
#29 |
