Need Help, clicking sound, Please Help
Hi, i have a 98' Chevy blazer, and when the truck is on, everyonce in awhile a clicking starts, on the passenger side, toward the glovebox. it comes on and goes away, it comes on when it fells like it, if anybody knows what this is please let me know, thanks,
Re: Need Help, clicking sound, Please Help
Multifunction Switch...
http://www.automotiveforums.com/vbul...d.php?t=577320 don't change your flasher/relay... i've googled it (same thing happened to mine last week) and its grease going over the contacts creating a short... |
ZQ8 Blazer
EBAY, that's where I got mine. About $50 cheaper than O'Reilly's
ok, would it be bad if i dont change it?
I just finished mine... took 2hrs total... i wasn't rushing and probably lost 30 minutes due to not getting the qtip in real deep...
note: you really need to get the Qtips in there deep... you'll also use a lot of qtips... watchout for the spring for the horn... make sure you don't lose it... also try it before you put everything back together... Regarding the Airbag: I only pulled the battery lead off and Air Bag/SIR fuse out... didn't unplug it... |
you want the qtip to go to the bottom of the 5 small openings...
be carefull there is a spring there that makes the contact... ![]() |
ok, so that is what is making the clicking sound on the passenger side then?
yes... it's been driving me crazy for 2 weeks now...
cleaned it up and all is good... like i said... just watch how you put it back together... |
so my question is, is it bad that i dont change it for a while? cause i just bought a house and iam a little short on money. And thanks very much for all this help.
no clue... i've read about people having it for like 2 years... i'd shoot myself if i had to listen to it for 2 years...
it doesn't cost you anything to clean it up... only some time... |
