Need help
Old 10-23-2009, 06:15 PM   #1
Juggalo 4 Life
93projectsdime's Avatar
Need help
I have a 98 Blazer with the 4.3. The problem is when I bought it I was told that the fuel pump needed to be replaced. I replaced it with a new sending unit and I still have the same problem. Every now and then when I go to start it, it turns over but does not start. It seems that if I turn the key back and forth a few times as to prime the fuel pump then it will start.I was thinking about the crankshaft sensor but that's only a guess. The engine light is not on. Other than that it runs just fine. Oh yeah, I forgot. Ever since I replaced the sending unit, the fuel guage does not work properly. Any help would be appreciated.
Old 10-23-2009, 06:23 PM   #2
nukem1st's Avatar
Re: Need help
You sure it's grounded good? There has been a lot of problems with fuel pumps being bad right out of the box, what kind did you get?
I have a 98 as well, and my fuel pump relay was corroded, make sure yours ain't the same way.
Old 10-23-2009, 06:25 PM   #3
Juggalo 4 Life
Re: Need help
I'll check that out. Thanks for the info
Page generated in 0.59524 seconds with 31 queries
[Output: 46.59 Kb. compressed to 44.60 Kb. by saving 1.99 Kb. (4.27%)]
