Need heat!!
Old 11-07-2008, 07:01 PM   #1
85_dime's Avatar
Need heat!!
The fan on my 96 blazer only turns on in the 3rd and 4th position. I was able to deal with it till today when the fan would cut out periodically for a few seconds and then turn back on. What the hell could it be? Its getting cold up here in canada!
Old 11-07-2008, 08:26 PM   #2
Re: Need heat!!
idk but mine does that 3 and 4 thing to kinda pisses me off, i wanna keep it warm but not that warm ya kno, if u get that fixed let me kno what it is id like to use my 1 and 2 speed also lol
Old 11-08-2008, 01:09 PM   #3
Registered (Ab) User
Yogi's Avatar
Re: Need heat!!
It could be a bad blower switch or a burned out resistor bank. I'd check the resistors first.
Old 11-10-2008, 12:08 PM   #4
85_dime's Avatar
Re: Need heat!!
Do you know if on a 96 the resistor needs to be cut out? Theres no unscrewing anything on the blower box.
Old 11-10-2008, 12:18 PM   #5
Yogi's Avatar
Re: Need heat!!
I've heard that but I don't know if it applies to the '96 or not.
Just get an ohm meter and check the resistors for continuity. No need to cut if they test out good.
Old 11-10-2008, 12:31 PM   #6
myxtremetoyz's Avatar
Re: Need heat!!
the resistor should unblolt from the hater box in the engine compartment I did one on my brother 96 s10 2.2 i'll try to find some engine pics
Old 11-10-2008, 12:43 PM   #7
Re: Need heat!!
Old 11-11-2008, 12:00 PM   #8
Say lowered d
loweredd's Avatar
Re: Need heat!!
I just looked in a Haynes manual, and it does confirm that on Blazer and Jimmy models, the blower resistor must be cut out of the housing for replacement, and the replacement must be glued in place with black weather-stripping adhesive.
Old 11-11-2008, 12:20 PM   #9
Vash's Avatar
Re: Need heat!!
In addition to fixing it you might want to get one of those electric ceramic car heaters. Plugs into 12v acc.
Page generated in 0.57350 seconds with 31 queries
[Output: 66.27 Kb. compressed to 62.15 Kb. by saving 4.13 Kb. (6.23%)]
