need advice
Old 10-27-2008, 01:35 PM   #1
need advice
well my 98 blazer is coming up to the 200,000 mile mark and want to know just with an answer if with the correct maintenance if the whole thing could make it to 250,000 or more. every thing seems strong and good but a few things.
1. when it starts it feels like it wants to die( stumbles a bit but is not rough,just not normal.)
2. it does shack and vibrate at 60 but good at 75.
3. it has a small oil leak/burn(one quart every 6 months)
i just need to know if i have a chance to get some good miles out of my blazer.
thanks to all
Old 10-27-2008, 02:06 PM   #2
The Dreamsicle
cpolaris502's Avatar
Re: need advice
those all sound like minor problems. The shaking should be fixable by just getting your tires balanced and/or the driveshaft balanced. The stumbling at start is probably just a small part to replace. The oil is what you will need to watch, but at this point, 250k sounds possible.
Old 10-27-2008, 07:57 PM   #3
Re: need advice
it does not smoke when i drive it . and it does look a bit greasy it the front bottom(i think the timing cover). it still drives great and powerful.
update: i sea foamed it and it runs REALLY GREAT now. it seems good now but i still would like to know about how long the engines and trans. work in these trucks if kept well. but i am going to degrease the engine and tell you all what i found
thanks
Old 10-27-2008, 08:02 PM   #4
immexicansostfu's Avatar
Re: need advice
i recently hit 180k and i had an oil leak to it was my oil cooler lines just replaced them it was real easy and no problems since. just search its real easy and takes just a couple of hours. and just a tune up you'll be fine man. make it to 250k and put a 5.3l in it !!!
Page generated in 0.55791 seconds with 31 queries
[Output: 49.97 Kb. compressed to 47.65 Kb. by saving 2.32 Kb. (4.64%)]
