Need A How To Bad!!!!
This is what happened to me, I’ve done a search with no luck but I know there’s one out there because its a common problem as I've been told.
I need to know if there’s Rivets to drill out or just some screws and how does the lumbar noob come of http://www.s10forum.com/forum/f26/pr...8/#post4616702 I just hope this does not get deleted as I really need help on this, the part is $125 and with tax comes to $142.Plus they want 1-2 hours to install it at so I really want to do it myself if you could maybe just say what needs to be done or if you have a picture or two that’s great. Last edited by Jimmys_4_life : 11-12-2007 at 11:25 AM. |
Re: Need A How To Bad!!!!
the link just takes me back to the homepage. What do you need to know?
The Dreamsicle
see if you can get just a new handle at autozone like 96blazer said in the other thread.
Blazen SS
hey... my passenger seat handle came broken.
i went to autozone and bought the repair set for like $12, i forget honestly. well, i went to put it on, and it didnt exactly line up/work right.. i drilled the hole out A LITTLE bigger, just enough for it to go on better. then i took a rubber mallet and hit it on tighter, got a longer screw.. and it is fixed. it sticks out just a little further then it should, but the thing was broken to far down and the replacement handle didnt work right.. so w.e. , it works... if you want i could help you out if you want to go this route... |
I have a $1 pair of vise grips I got from walmart on mine. I really have no intentions of really fixing it either.
