Need 99 Envoy Body Diagrams, Diagrams for front cowl
Can someone provide me with a diagram or inform me of how this piece (with the arrow) is attached to my 99' GMC Envoy. I am getting some rattling when driving and I think this is the cause because it is loose at the top and upper-left side.
Finished
Re: Need 99 Envoy Body Diagrams, Diagrams for front cowl
It attaches with one clip and a plastic screw under the hood. The plastic screw can be hard to get out. You can just pull the head of the plastic screw out with a pair of needle nose pliers. The whole screw should just come out. Once unscrewed just pull up gently on the piece and it should unclip.
Polishing Guru
okay, ya what he said
![]() Last edited by samandjen1 : 01-11-2006 at 12:00 PM. |
So if the clips and screws are at the bottom under the hood, then the top sides should be loose? Or is the cowl just worn and the plastic has become soft?
Polishing Guru
Polishing Guru
there
Thanks for the help guys. I will check to make sure that clip is there and report back.
