MPG's
god damn, i just filled in northside of Chicago and for 16.79 gallons = 73.00
i was able to pull of 17 miles per gallon for that week not bad for 1996 Jimmy w/129k miles |
The Dreamsicle
Re: MPG's
that is rediculous! we used to be able to fill our suburban's 44gal for that much.
$4.35/gal? the world is coming to an end soon... Last edited by cpolaris502 : 06-01-2008 at 01:52 AM. |
Re: MPG's
i forgot to mention 87 octane
Has Training Wheels
Re: MPG's
all the signs in town are pegged at $3.89 for 89oct and $3.99 for 87oct
went up to the lakes and seen $3.84 89oct and $3.94 87oct dunno if thats actual prices or if gas is over $4... i have a 3 cent off gallon coupon.. but it doesnt really take much off, 10 gallons is 30 cents.. it helps, but it doesnt do anything im above 1/2 tank and ive gone 130ish miles |
Re: MPG's
I have gotten up to 23mpg out of my 93 2dr
Re: MPG's
is that street or HWY? |
Re: MPG's
I've gotton 20.5 MPG at 80 MPH!! With four doors and loaded!! Reprogrammed PCM!
The Dreamsicle
Re: MPG's
my max is 24.5 on the highway.
Re: MPG's
My 98 blazer is getting 20mpg |
ZQ8 Blazer
Re: MPG's
Mine was getting 18 mpg, after I lowered it and put the exhaust on it got 20 mpg, but I haven't figured it up in months. it has 142k on it. Inow drive 10mph lower than the posted speed so I need to figure it up again **** all those idiots that speed!
Re: MPG's
i think the most i ever got was 23 - 24 on long highway trips that was with 120k new pluds wires oil change and tires
now im pulling like 20-22 on the long higwasy trips short higway is like 20 i think city is like 17-18 mix and mach would be like 18-19 and that is with 156k |
Re: MPG's
Alright!! Went through the first full tank after having the PCM reprogrammed. Normally MPG were 16-17. The first tank put out 18.5! Or about 1+ MPG more. Even with being stuck in dead stop traffic for 1 hour. At that rate, the $85 will pay for it self quickly. Not bad for a 4 door and simple modifications done to the Jimmy.
Re: MPG's
i get regularly 15 city driving only. I recently did a tune up and still the same. I am gonna be doing a water pump, intake manifold gaskets and while im at it im going to do the 03 and up injector setup as mine seems to have a miss to it still.
All this on a 98 blazer 4dr 2wd with 140k. |
Re: MPG's
You should see a slight improvement with the updated spider. My Jimmy 4.3 responds very nice to throttle demand.
I think the next mod is an electric fan. Texas is hot, so the clutch fan engages any time I turn off the engine for little bit. Even idling at a light or traffic, the clutch fan engages with the A/C on. Did I mention mine is a 4 door Jimmy? +155322+ miles on it too. |
Re: MPG's
i was getting about 18-20 out of mine but needs tune up so only getting 16 right know. i have a 97 blazer 4x4 4 door with 130k. and that was mixed driving.
Moderator
Re: MPG's
my blazer gets 15mpg in town.
i drove one tank SUPER slow and didnt get on it any and got 13 mpg.. gay now that i got the 2.2 s10 running good i plan on driving that some! |
ZQ8 Blazer
Re: MPG's
^WTF? What are you do you have 2 plug wires loose or something crazy? My grandfathers 97 ext. cab Z-71 does better than that.
Re: MPG's
Is it trued that when you run your AC your MPG goes down and by how much would you say it would go down ?
Slap my meat on your pita
Re: MPG's
AC on around town will hurt your mileage, but if you are on the highway AC helps. |
Re: MPG's
man i just hit 221miles i'm just a little over the the halfway mark. street and hwy. i'm working on a oil change, pcv, whipper blades, a/c, alighment, tire balance, rear axle seal replacement, differential fluid change and rear brakes. should be done tonite.
Re: MPG's
I am confused how come ac hurts on city but helps on higways ?
just called the mechanic going to get the fuel filter changed going to charge me 79 for a fuel filter and the labor plus tax will a fuel filter help the MPG ? |
ZQ8 Blazer
Re: MPG's
I seen the mythbusters where they tested this theory on 2 identical cars and they got the same mpg. However this wouldn't be true for all vehicles. The pulley is always spinning but when you turn the a/c on the clutch lets go putting a slight bit of extra load on your serpentine setup. Now that clutch also kicks in and out when the a/c is off, it does this to circulate the oil so nothing locks up. This is one good reason why there will be very little difference in mpg weather the a/c is on or off. You may get slightly better mpg if you took the a/c compressor out, but it's not worth it.
You'd get worse mpg in the city than the highway for 2 reasons. 1. stop and go driving. 2. with the stop and go driving and the a/c running the engine has to work a little harder on take off, while with highway driving you already have your rpm's built up and it's still working slightly harder than if the a/c was off, but not as hard as when you take off. |
Blazer User
Re: MPG's
i got a ?:
how do you guys know exactly how much miles youve driven on an exact gallon of gas? |
#24 |
Re: MPG's
just taking a guess the way i do it is ill filled up the tank before a roud trip then get on the hhighway make sure the station is righ tnext to the highway then ill drive and ones i hit half a tank ill refill and then ill take how much gas i had to put in the car then ill devide it by how many miles i have driven
#25 |
ZQ8 Blazer
Re: MPG's
I just know that a vehicle uses more gas in the city than the highway. To figure my average mpg up I:
Fill the tank all the way up, record how many miles are on the odometer, use 1/2 tank, fill it up again, record the miles on the odometer. Subtract the 2nd recording from the 1st to get how many miles I went on 1/2 tank. Divide that by how many ga. it took to fill it back up. |
#26 |
Has Training Wheels
Re: MPG's
i use the trip odometer
fill up till tank is topped off, reset trip and leave gas station, drive till near 1/2 tank and top the tank off, say i used 10 gallons and i drove 200 miles, that means average is 20mpg. easiest way. it averages it all together, so if you do 50/50 city and highway itll be mixed. if you want highway, you have to fill up and start over before highway and after highway |
#27 |
Re: MPG's
#28 |
The Dreamsicle
Re: MPG's
and yeah, just reset the trip everytime i fill up. now with my Bravada overheard console this year, it will tell me all of that and more. |
#29 |
Molon Labe
Re: MPG's
Who drives on the hwy with the windows completely down? |
#30 |
Re: MPG's
The most efficient MPG change is locking the torque converter. GM used very loose converters and programming. Especially on 4 doors. Reprogramming the PCM is necessary. Saving 200-300 RPMs increases MPG.
#31 |
Re: MPG's
can i set it up to work in the jimmy ? |
#32 |
Re: MPG's
#33 |
ZQ8 Blazer
Re: MPG's
#34 |
Re: MPG's
At any speed until it locks. The torque converter spins more at take off. It will slip less as you pickup speed. At highway speed 200-300 RPMs is common.
I wish I could lock it in 3rd gear. Due to city driving. My old 83 locks the converter in 3rd gear. I drive mostly in 3rd in town. Electronic transmission don't lock the torque converter until OD. |
#35 |
The Dreamsicle
Re: MPG's
#36 |
Re: MPG's
#37 |
The Dreamsicle
Re: MPG's
as far as i know they are pretty standard, you're 97 should be the same for the wiring of it. i dont know for sure though.
#38 |
Re: MPG's
I was averaging 18 or so now 15.5 after a new fuel pump and sender
#39 |
Registered (Ab) User
Re: MPG's
#40 |
Re: MPG's
now do i need to look for 1995 - 1997 or will the units be the same from 95 -2001 so i get the same thing that i have without the sunroof buttosn ? |
#41 |
Re: MPG's
They look the same. I put one from a 2002 Bravada in my '98 Blazer and it works, but the gas mileage is off by a couple of mpg. My '98 came from the factory with Homelink & digital trip computer so I didn't have to worry about the harness. I don't know what you mean about the sunroof buttons.
#42 |
The Dreamsicle
Re: MPG's
you need a long console, they are for trucks without a sun roof. you will be able to tell very easily because the short one is like less than a foot long.
#43 |
Re: MPG's
woo made it up to 315kms this time :P good $78 dollars spent to fill her up to..canadian
#44 |
Re: MPG's
i did a few searched called on yard about 2 hours away they are going to call me back tomorrow and let me know he has a few bravadas out there so hes gona look in the morning
there isnt some guage i could go buy that is a digi that i could hook up that would tell me about how many miles i have exactly or that tells me how many MPG i avg is there if i cant get ahold of one of these local or close buy is ther a gugage i can go pick up somewhere ? |
#45 |
The Dreamsicle
Re: MPG's
no, its all read off of the computer and stuff. so, unless you want to do some major electrical work, the bravada is the only way to do it. or like i said, you can just swap out the compass part of it and the wiring.
#46 |
Re: MPG's
The Scangauge (Click here) will work for you.
Your best bet is to get a console off E-bay. That's what I did. $49. Last edited by Yogi : 06-13-2008 at 11:29 AM. |
#47 |
The Dreamsicle
Re: MPG's
