Miles per hour and engine rpms
Old 05-25-2006, 09:34 PM   #1
I have a 95 Blazer with the 4.3 engine and the 4L60 gearbox. When cruising at 120 kph ( 75-80 mph) the tach is pointing to 2700 rpms which is, my opinion, a little high regime for this huge engine. Measured (carefully) mileage is of 8 kpl (18.8 miles per gallon) at the hwy. But I can't compare the Blazer with any other. Which is your rate of rpms when cruising at similar speed?. My speedmeter is 100% accurate (GPS, stopwatch). The tires are 255/60 (stupid former owner). Thanks.
Old 05-26-2006, 12:04 AM   #2
I pee standing
juddspaintballs's Avatar
Re: Miles per hour and engine rpms
96 jimmy 4 door 4wd with auto trans. at 80mph I run just a hair over 2500rpm on level ground and careful measurment several times I average about 21-22 mpg depending on the driving done on that tank of gas. but thats with a couple modifications to airflow on the engine
Old 05-26-2006, 12:29 AM   #3
Unregistered User
j894's Avatar
http://www.csgnetwork.com/multirpmcalc.html
Page generated in 0.55705 seconds with 31 queries
[Output: 46.60 Kb. compressed to 44.63 Kb. by saving 1.97 Kb. (4.24%)]
