MAP Sensor Issue
Well, I have a 1999 Blazer LS 4d 4x4 4.3L that's spitting out a P0108 code (Manifold Absolute Pressure/Barometric Pressure Circuit High Input).
A bit of history: Had a coolant leak that turned out to be a Intake Manifold Gasket. Cleaned the Intake Manifold really good, got a gasket set and re-installed. The car runs good but for the annoying Service Engine light. I replaced the MAP sensor, erased the code and now its back. Any ideas? Could it be an incorrectly routed vacuum line? Could it be that I didn't seal the Intake Manifold correctly? I used silicone like a MoFo but you never know. Any assistance would be appreciated. A color Pic of the Vacuum lines would also be great. Last edited by arolon1965 : 11-04-2008 at 06:08 PM. |
Re: MAP Sensor Issue
bump
Registered (Ab) User
Did you get it resloved? If not, you might try posting in the 4.3L section.
didn't get it resolved. Will post in 4.3 section.
Thanks for the pointer Yogi. |
Good luck!
