lube/greasing the front end
Old 09-03-2008, 04:19 PM   #1
Goran's Avatar
My envoy is squeaking like a Donkey...
does anyone have the link for the lube fittings?
or any ideas why it's sounding like a Donkey?
Old 09-03-2008, 04:25 PM   #2
whore turned lurker
dimerunner88's Avatar
Re: lube/greasing the front end
whats a donkey the squeaks sound like?
anyway there should be grease fitting on your upper/lower balljoints,tie rod ends and your steering linkage. there should also be fittings on your u-joints on the driveshaft.
Old 09-03-2008, 05:20 PM   #3
If it's squeaking then the hcances are your control arm bushings are making the noise or the spring rubbers are history. It will be easy to tell though because the old front end parts should have fittings on them for grease.
Old 09-05-2008, 11:13 AM   #4
Goran's Avatar
HEre's the link i was looking for...
http://www.s10forum.com/forum/f198/h...nt-end-103812/
Old 09-08-2008, 07:54 PM   #5
Still fixing the Blazer
joshuaT's Avatar
A donkey doesn't squeak, they bray. You know Hee Haw. I went to Autozone and I got some poly grease to go in my poly bushings. It still squeaks a bit but I don't mind.
Page generated in 0.56300 seconds with 31 queries
[Output: 52.86 Kb. compressed to 50.17 Kb. by saving 2.69 Kb. (5.09%)]
