Lowering a blazer
I have a 2WD GMC Jimmy that I lowered 3/4(springs and blocks). My problem is that the front is sitting approximately .50 of an inch higher in the front. Will the springs settle over time? Or should I go ahead and order 3 inch blocks? I was wondering if I removed my fullsize spare from the rear if that would do the trick.
UNDER CONSTRUCTION
Re: Lowering a blazer
if you just finished it? yes let it settle for a week or so.
yeah, I just finished it today. It's buggin the hell out of me.
FAHQANDFAHQ2
when i put mine in man...it settled about 3/4 of an inch so if thats all your worried about it should please you after it does...after i drove mine 45 minutes i remeasured it and BAM...i was a full 5 inches lower than stock
I'll probaly just go to a 3 inch block.
Starting from scratch...
Is it still not settling down, or is it simply that you prefer the semi-raked look? I'm about to drop a few bucks on some 3" springs, and I'm curious to see if it's dropped a little bit for you since the initial installation...
FAHQANDFAHQ2
quick question....is there a Co. that makes 3 inch drop springs for 98+ blazers?...
http://www.jegs.com/i/Ground+Force/476/9921/10002/-1
go to groundforces website, thats the kit they say to use. at least it is on my 01 |
FAHQANDFAHQ2
no i mean for the rear...i shoulda said drop leafs...lol i got 3 inch drop springs in mine already with 2 inch spindles...
FAHQANDFAHQ2
holy hell thats highway robbery...lol...belltech are nazi's...i just choked out 300 for spindles!
This is doo doo baby!
I have a set sitting in my garage but they're probably going back on the blazer
FAHQANDFAHQ2
i want a set but ima bag it eventually so its like SHIT...300 bucks could go a long way to bag my front right now...lol
SmartTrak FTW
FAHQANDFAHQ2
yeah and i think ima go the same way cory...lol...i get mad enough ill just pull a leaf and bag the front...lol...Air Zenith is right here in town so ill go rob them...lolol
FAHQANDFAHQ2
try driving it for about an hour straight man...take it over some speed bumps n such...work ker out...lol...it should help some
Try putting ZQ8 springs in the front. That's what i did to mine.
can't I used 3 inch springs up front. Does anyone know of a company who makes 3 inch angled blocks?
They're a little pricey compared to most blocks, but they're built like a brick shithouse, and you can buy angled shims that bolt right to the top of the block in several different degrees to get the best pinion angle for your situation. They even have 1/2" blocks that will bolt right to the main block also. |
Founding member of DA
are the springs seated correctly in the front?
Blazer X
Just cut a half a coil off
#24 |
Oh, i thought you had spindles ......
#25 |
was it level before or did the rear sag? leafs are probly weak
#26 |
#27 |
FAHQANDFAHQ2
you should be fine with just a 3 inch block...the pinion angle isnt very bad at that height on a blazer...anything over 4 inches or if you run a block with drop springs you need to adjust the angle
