LOUD humming on decel
Old 08-05-2008, 01:53 AM   #1
I have a 1999 automatic 4 door 4x4 blazer.
When I accelerate above 45 mph and start a decel, at anywhere between 45 and 40 mph a LOUD humming starts that seems like it's coming from the front driver's side of the vehicle.
If I barely touch the gas the sound goes away, but comes back until I decelerate into the the mid thirty mph range.
The sound is not present, or maybe just not noticeable on acceleration only on a decel.
When I steer back and forth, while hearing the noise, it doesn't go away. The sound is present in the other gears as well.
The one interesting thing is that I can't reproduce it in four wheel drive.
I have had about a half dozen mechanics ride with me getting such interesting responses as it's a problem with the...
Wheel bearing
Transmission
Transfer case
Differential
While I appreciate their enthusiasm, that's a pretty wide variety of components to "examine" just to search for the cause at my expense.
You guys have any ideas for me before I fork over a wad of cash?
Old 08-05-2008, 01:20 PM   #2
Registered (Ab) User
Yogi's Avatar
Re: LOUD humming on decel
I would check the u-joints on the front drive shaft before anything else.
Old 08-05-2008, 01:22 PM   #3
Local Tech
ls1s10onair's Avatar
ur front diff. is taking a shit..... sounds like the inside pinion bearing to me
Old 08-05-2008, 02:26 PM   #4
Overhead Console Expert
raven2510's Avatar
wheel bearing...
Old 08-05-2008, 02:30 PM   #5
It's a Blue thing...
♠ M®. ßlυε ♠'s Avatar
Front hub assembly
Old 08-09-2008, 09:37 PM   #6
mrriverajr's Avatar
Hey any luck this is happening to me also???????
Page generated in 1.84486 seconds with 31 queries
[Output: 56.59 Kb. compressed to 53.55 Kb. by saving 3.04 Kb. (5.38%)]
