Leaking coolant
Old 09-03-2008, 10:39 AM   #1
I piss excellence
Kaznlilgreenmen's Avatar
Leaking coolant
Ya...01 Jimmy 4.3 I have like a slow leak in my coolant somewhere along the lines, its leaking from the left side almost from the radiator..anyone have any problems with leaking hoses or anything? Did a pressure test..won't even hold 5 psi...and its pissin me off cause I have to keep filling it and the mornings are getting colder here and the heat aint workin.. Any ideas..? and I really don't wanna replace the radiator but that seems where the leak seems to be coming from...Also tried a bottle of radiator plug..that didnt help..
Old 09-04-2008, 12:24 PM   #2
Registered (Ab) User
Yogi's Avatar
Re: Leaking coolant
Fill it up and do the pressure test again. It should come runnin out at the leak under pressure. Look close at the intake manifold to head joint. They're notorious for leaks.
Old 09-04-2008, 12:41 PM   #3
I piss excellence
Re: Leaking coolant
I'm replacing the radiator on sat (joys of workin at a dealership I get parts cheap) From what I gather they are also infamous for leaking at the side tanks where they clip on the radiator which where mine seems to be leaking..so we shall see ty for the input tho
Old 09-04-2008, 12:46 PM   #4
Yogi's Avatar
Re: Leaking coolant
Yeah, been there too.
Good luck!
Old 09-04-2008, 01:01 PM   #5
I piss excellence
Re: Leaking coolant
Good luck!
haha thanks its not tooo bad I can get at it from the top so
Old 09-05-2008, 12:09 PM   #6
It's 4:20 Somewhere!
SmokeeJay's Avatar
Re: Leaking coolant
Changing the radiator is very simple. I think it took me an hour to change mine, with a smoke break here and there :-)
Old 09-05-2008, 12:31 PM   #7
Yogi's Avatar
Re: Leaking coolant
A "smoke break"? Like the one in your avatar?
Old 09-11-2008, 05:19 PM   #8
Calvin51's Avatar
Re: Leaking coolant
One small tip...the lines have a small clip that holds them on. They do not unscrew out of the tank. Pull you battery for a little clearance, unbolt the shroud, unclip the lines, unhook the hoses and it is clear to come out. The first one I changed I unscrewed the tranny and cooler lines. The second one I change was a little less than an hour. Got mine at Advanced, in stock, but it was $250.00. Price went up because a year or so ago I think I paid $189.00. But if ya need 'em ya need 'em.
Old 09-13-2008, 10:12 AM   #9
Registered Neanderthal
SH-60B's Avatar
Re: Leaking coolant
Get a new cap, t-stat and flush the old coolant while your there.
Old 09-13-2008, 02:12 PM   #10
Re: Leaking coolant
well, that radiator plug is probably why your heat doesnt work, that crap gets all int he heater core and gummmms up EVERYTHING....
Old 09-15-2008, 01:05 PM   #11
I piss excellence
Re: Leaking coolant
Eh I bought a brand new radiator 120.00 dealer cost...gotta love workin for one...I was one of the bull clips on the side of the tank that was messed up..ya while I was at it I flushed out the whole coolant system, heater core and all..total time was a little over an hour biggest bitch was getting the lower fan shroud back in its clips But she is all done and runnin good...for now *fingers crossed*
Old 09-15-2008, 01:07 PM   #12
Yogi's Avatar
Re: Leaking coolant
Glad to hear it!
Old 09-15-2008, 03:44 PM   #13
SH-60B's Avatar
Re: Leaking coolant
Yay!
Page generated in 0.59065 seconds with 31 queries
[Output: 80.97 Kb. compressed to 75.41 Kb. by saving 5.56 Kb. (6.87%)]
