keyless entry/BCM
Hi all,
I replaced the Body Control Module on my Bravada to fix the ever-annoying Passlock problems I was having. The wonderful thing was that it worked! No more "security" light, no more failures to start, etc. Unfortunately, my keyless entry no longer works...great. I thought maybe it was just a matter of reprogramming the remote to match the new BCM, but that does not seem to be the case. Does the BCM have to be "programmed" to "know" that a vehicle has keyless entry or something? Maybe a feature that has to be somehow enabled? Both BCMs had the exact same part number, I can't imagine they are different hardware... Anyway, if someone understands/knows how the keyless entry feature works I would appreciate it! |
Banned
Re: keyless entry/BCM
did you plug the keyless entry FOB module back in that is mounted to the panel on the underside of the driverside dash?? its back behind the OBD 2 connector on top of the panel.
I have seen them need to be programmed, but not sure if that would cover the keyless entry. Is that the only thing not working right? |
I have tried the programming sequence a few times (hold down driver's side lock, etc, etc) but it just acts like keyless entry is no longer there, very strange. |
Banned
ok, well did you try puttinig a new battery in the remote fob? ive seen that be the problem as well, and usually they die pretty hard and quick, so you dont always know its the battery till one day they quick working.
A bit of net searching seems to indicate that the BCM has to be set up to enable keyless entry as a feature; I have yet to verify this but may take it to the dealer to find out. |
5 speed 4 door blazer
you need to reprogram the bcm. i had the same problem
