Jimmy vs Envoy Rear suspension
Old 10-28-2008, 12:40 PM   #1
Goran's Avatar
Other then the air ride suspension in the Envoy what's the difference in the rear suspension?
i took out the old air ride and put regular jimmy 4x4 shock absorbers in, and the back still sags?
Old 10-28-2008, 01:15 PM   #2
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
Re: Jimmy vs Envoy Rear suspension
Just crank down the torsion bars at that front and level it out, lol
Old 10-29-2008, 05:05 PM   #3
Slap my meat on your pita
GeorgesBlazah's Avatar
The sprigns in the rear of these trucks are notorious for sagging. Depending on how much yours sags you may be able to get a set of shackles or add a leafs to bring it back up again. 3leaffab.com I belive makes 1in shackles, those may do the trick.
Old 10-29-2008, 06:49 PM   #4
K Dawg ONE's Avatar
Also, there is a set of new helper springs for sale on kijiji...i saw the same ad on kijiji windsor as well as st catherines. I think the guy wanted $60 or somthing....take a look...
Old 10-29-2008, 07:59 PM   #5
And for the record, any add a leaf or helper spring will stiffen the ride up some. Shackles will not. If you tow or haul decent amounts of weight, get the AALs, otherwise get some shackles.
Old 10-30-2008, 09:41 AM   #6
Goran's Avatar
can you PM me the link, i've looked and can't find it?
Thanks
Old 10-30-2008, 02:53 PM   #7
K Dawg ONE's Avatar
PM sent...
And actually, they are only $25!!!
Page generated in 0.56738 seconds with 31 queries
[Output: 60.19 Kb. compressed to 56.77 Kb. by saving 3.42 Kb. (5.68%)]
