jimmy envoy turns over but won't start
Old 03-15-2008, 01:09 PM   #1
i was driving my truck, 2000 jimmy envoy, around last night everything was cool. never had a problem with it. i come outside this morning and it turnos over but won't start. maybe its something with the fuel or ignition. any suggestions will help
beav
Old 03-15-2008, 11:38 PM   #2
evanbisyo's Avatar
Re: jimmy envoy turns over but won't start
Fuel pump? just a thought
Old 03-16-2008, 12:51 AM   #3
need more info on this one, when u turn key to run can u hear fuel pump? does it start at all or did it at all? anything u can provide helps
Old 03-16-2008, 11:20 AM   #4
Shawn-GMC's Avatar
maybe a bad battery?
Old 03-19-2008, 11:41 AM   #5
Registered (Ab) User
Yogi's Avatar
beav
When my '98 did that it turned out to be the fuel pump.
Old 03-19-2008, 04:29 PM   #6
thats the same problem with my 97 4door Blazer- i go out to start it today and it turns over but won't start, and a couple days after i got the car i could hear the fuel pump. i guess the 1 day i didnt drive it it just decided to completly stop working
Old 04-02-2008, 08:12 AM   #7
My '96 Jimmy has done this to me 3 times in the last 4 years. First time it was the fuel filter. (it was starting harder and harder and had some hesitation on acceleration then wouldn't start one morning) Not an easy job, but replaced the fuel filter and end of problem. Second time it died going down the road. Shop couldn't find anything wrong then just for the fun of it, replaced the ECM 20 amp fuse WHICH WAS NOT BLOWN and it started right up. Third time it was the fuel filter again. Same simptoms.
Old 04-02-2008, 10:22 AM   #8
Goran's Avatar
same thing happened with mine...
fuel pump...
Old 04-11-2008, 07:59 PM   #9
94 s10 in progress
FxsX24's Avatar
check ecm fuses under the hood, my ecm1 fuse blew and killed the truck
i think the injector wires came loose, has been fine since
Old 04-28-2008, 01:52 AM   #10
Vashthestampede's Avatar
I'm sure this has been resolved by now. But I had 2 99' Envoys that had fuel pumps fail. And I know of 2 others that had the same problem. Envoys (not sure about blazers) are notorious for fuel pumps going. Just wanted to add that info.
Vash-
Old 04-28-2008, 09:40 AM   #11
Yogi's Avatar
Blazers are the same.
Welcome to the forums!
Page generated in 0.57410 seconds with 31 queries
[Output: 72.61 Kb. compressed to 67.81 Kb. by saving 4.80 Kb. (6.62%)]
