It's a Blue thing...
Is my 98' Jimmy worthy of going off road?
I wonder if my 98' 4x4 Jimmy is worthy of going off road. If not, which I don't think it is. What do I need to upgrade to make it trail ready? Tires, lockers?
I'm not going to do anything crazy just yet, but want don't want to get stuck on a muddy hill or a rocky grade. Right now it sits stock. |
www.oaktowntrucks.com
Re: Is my 98' Jimmy worthy of going off road?
stock there ok with good tires
just look at are site http://www.wegotmud.com/ and look at all the pic's there is a ton of stock blazers out there and they do good just know your limts and go with a buddy but every little thing you do locker tires lift etc..... will help!! |
Hey, suncad where you at in Lapeer? I'm there too.
Anyway, the only immediate upgrades I'm looking at for my stock 98 Blazer is Cooper Discovery STT tires, 30x9.5", and ZR2 front and rear gears (Posi rear with 3.73 gears). I think even if you just went with a bigger tire, you'd be okay, or just an offroad tire. |
I want to do a straight front axle swap sometime. Do you guys know where I can buy a coil lift kit for the front?
Is this site for real? http://www.setstr8.com/
Where can I buy a kit like this? ![]() ![]() ![]() We are proud to announce the release of our all new GM S-series Straight Axle Conversion. This much awaited product has been the sole focus of our research and development department for some time now, and we believe the end product was a great reward for all of our efforts. Here are the specifications: Utilizes a Dana 30 straight front axle from a Jeep Cherokee/YJ 4-link setup utilizing coils Dual shock system Sway bar assembly available Available in 9" lift height, and soon available will be 11.5" lift height All bracketry locates off of existing factory holes ( 8 holes to drill) Frame bracketry removal required along with minimal welding (coil tower support sleeves) Front driveshaft modifications required -- If equipped with constant velocity style shaft, transfer case adapter will be required No modifications to the Dana 30 housing is necessary Kit contains coil towers with bump stop assy., adj. trac bar, coil tower support bar, upper/lower 4-link bars, rear 4-link mounts (4), trans. x-member, coil retaining hooks, coils, brake lines, pitman arm, main tie rod assy., drag link assy., all necessary hardware and bushings. |
and you can get 9" with a lift no prob and keep the EIF front that is a good set up it will give you more ground clearnce but if you go with straight axle get ready to bend over i would spend my cash on more motor upgrades and do a nice bds 6" lift and get 35" tires and go thru a lot if you are going for big you will need a hole new drive line 33" tires in mud will dog a 4.3 just my 2 cents i have seen a lot of wasted cash on parts that do not help |
just get a K5 JImmy, you'll be set...i wouldnt want a newer s series blazer/jimmy for off roading, or new fullsize for that matt...they have IFS....K5 all the way :-D
Slap my meat on your pita
who says ya cant offroad with your truck? i do it with mine. some of us cant afford another truck to use for offroading.
![]() check out the Liftin' It forum to answer your questions Last edited by GeorgesBlazah : 12-22-2005 at 08:18 AM. |
and you can laff at the guys that have over $8,000 in ther rig and hit 2 hols and are broke (i am one of those ) so just have fun |
My buddy has a K5 and its junk. Its a tank but doesn't do to well wheelin.
I got my Jimmy wheel it and thats what i'ma do with it. |
then its a newer body k5...the olds ones=mudqueen :- though if its trails your after than of course you dont want a fullsize pig :-D but a K5 is mud ready stock :-)
Salvage Title
Hey I own a 94 Sonoma 2nd gen truck and it has a solid axle swap and it ride's liek shit. Looks badass but rides real rough!
Salvage Title
[img]file:///C:/Documents%20and%20Settings/Jim%20Kremsreiter/Desktop/My%20Stuff/Pictures/sonoma_front.jpg[/img]here's my solid axle sonoma
Thats pimp, I've seen it for sale before in the classified section. Did you use leaf spring lift in front for that SFAS?
I don't mind a rough ride, its 4x4 for cryin out loud! |
Salvage Title
We used the original leafs from the Wagoneer. Welded and fabricated some steel brackets to mount the leafs to in the front. The origianl sonoma shocks were used in the application.
ajsproaudio...got any pics of the suspension setup?
Salvage Title
I'll see about taking some pics for ya.
You can definately take your Jimmy/Blazer off-roading, even next-to stock. I took my '97 2-door Blazer out this weekend and it did better than my buddy's stock Wrangler. The only mod I have is 30 inch tires. We both climbed a pretty steep mound of dirt, and I made it up without hittting anything. He hit his skid plates. Although now his Jeep is lifted 4 inches on 31's...
. So I say go for it. Just have a hose ready when you come home!! ![]() |
I want to put some mini boggers on it. I don't think they make them small enough to clear it in any way.
Do they make body lifts for 98+ S10 Blazers/Jimmys. How much work to get them on? Do you have to extend or modify anything? If I can't run boggers at stock height or with a body lift, then i'll run a Super Swamper TSL, I believe they're called. |
blue check out the lifted forum theres a tons of posts about all that stuff in there
not too many of them in the lift forum have 4dr blazers or Jimmys. Everyones got pickups.
#24 |
its all basiclly the same chit. let me know what questions you got because chances are ive already done it to my truck.
#25 |
If I run a 215/85R15 TSL tire, would I rub any? My Jimmy is sitting completly stock. With street suspension.
#26 |
i doubt it, thats like a 29x9.0
