Hub Bearing Gone........but which one?
Old 02-26-2006, 12:27 PM   #1
Canadian Dictatorship
Holeshot's Avatar
Time to replace another worn hub bearing assembly.
Trouble is - which one? Here's the symptoms:
When driving straight or turning left - it makes noise.
When turning right it goes away.
I seem to remember that it's the opposite side from which the noise goes away when turning, in this case - the drivers side.
Anybody confirm this?
Old 02-26-2006, 01:09 PM   #2
I-70 scrapper
psssssstblazer1's Avatar
Re: Hub Bearing Gone........but which one?
you got the squeaky noise too huh? sounds alot like mine, it was the passenger rear that went out.
Old 02-26-2006, 02:01 PM   #3
Holeshot's Avatar
The rear doesn't have a hub bearing assembly.......
Without a doubt - it's the front.....only which side?
Old 02-26-2006, 02:49 PM   #4
I-70 scrapper
Yeah its the passenger side when turnning right goes away........... oops front right I ment
Old 02-28-2006, 05:42 PM   #5
V8 Member
the_dubster98's Avatar
if i was you and had the cash id just do both, cause what i have noticed with mine, once one gets fixed the other is making noise too or will shortly after...
how much of a PIA was it? my warranty is up in 20k just curious cause this is one of the common failures on the 4x4 or at least according to the dealership
Old 02-28-2006, 11:07 PM   #6
Holeshot's Avatar
It's a bit of a pain getting the center nut out.......but other than that - it's really just a half hour job.
Old 03-05-2006, 09:55 AM   #7
They still last a long time from when you first hear the noise. If you can get it up in the air, you can see the play in the bearing by pushing on the wheel, if its really bad or just by rotating the left wheel and then the right and listening. 100 -150 km is all they last.
Old 03-19-2006, 10:41 AM   #8
Holeshot's Avatar
I changed it last night.
Good thing I did it when I did - there was a helluva lot of play on it!
Ended up getting one from Napa for just under 3 hundred bucks.
I found a couple of places that would sell me used ones - only they are just as likely go after six months so I went new.
Page generated in 0.57151 seconds with 31 queries
[Output: 63.10 Kb. compressed to 59.34 Kb. by saving 3.76 Kb. (5.95%)]
