How to remove rear door panel without brakin it.
Hello I have a 97 blazer 4 door.
A rear spreaker is bad. What needs to be removed to dissamble the rear left door panel. Thanks Bob |
keepin it freshhh
Re: How to remove rear door panel without brakin it.
there are two screws in the arm rest handle, and the door panel is held on by many snap clips that you can carefully remove with a fork or you can just yank on them
forum idiot
a fork?
you also forgot to mention the two parts up top that need to come off one is held in by clip the other is by two scews...or the fact that the part under the door handle has a screw.. the ones in the door where you grab to close it are covered by a small cover...use a flat head screw driver to pop that up..there are 2 7mm screws under there...remove them...now remove the screw behind the door handle ..its plastic and they like to strip...also use caution cause the plastic likes to break...remove the two upper door trims that go up and then use a door panel tool or even just get your fingers under the panel and pull towards you..and the door panel should just snap off |
keepin it freshhh
fork?
my weapon of choice |
Thats a fork. What your talking about is a panel tool never herd it called a fork. |
forum idiot
