SK Whut !?!
how to fix rear blazer windows
Well since i didn't see a how-to on how to fix rear windows on here i decided to make one when i did mine.
since i did a complete repaint on my blazer i had my windows out so i wouldnt have tape lines anywhere heres some of the stuff i used. i forgot to take pictures of the glaze and steps in painting ![]() heres before on windows ![]() ![]() i then cleaned the windows front and back with a foaming window cleaner from the dollar store. and i went from there. i got some tape and masked off the back side by the vents so primer wouldnt get on the windows ![]() then i actually used the fine line tap on top of the rubber edge just a little so that incase you had to use some glaze it wouldnt be on the window. so i stayed about 1/8 inch on the rubber all the way around with tape. and then went over with 1 inch tape on 18 inch masking paper. and masked the whole window. my bottom edge wasnt messed up so i covered that. ![]() then i decided to go over it with 400 at first but wasnt cutting good so i went to 220 on a da ![]() after sanded a little it needed some filler. so i cleaned the edge off with some 3m 382 enamel reducer and then sprayed some nason etching primer on it. ![]() ![]() ![]() heres the window with etching primer on it ![]() here i used evercoat oem metal glaze ![]() then i went over that with some 180 and got it close to what it needs to be and primered it ![]() i waited a few days incase the glaze was to shrink or not. the window was out in the sun for those days. then i took some 400 and wetsanded the window and where i had hard primer lines to remove them and unmasked the window. i then cleaned the window again and used fine line tape on the window this time as close as i could get it to the rubber. and then after it was all masked i took a red scotch brite pad and went on the bottom of the window this time since i wanted it painted. after that i used 3812 again and wiped it off wetsanded ![]() remasked ![]() then here it is sealed, painted and cleared. ![]() finish back on the car ![]() and heres the truck... the leafs i was told to fit a blazer and s10 leafs only fit s10s. blazer leafs are shorter by 5 inches. im waiting on lowering leafs and i need to put my spindles on it. ![]() Last edited by kms_dude1 : 07-03-2008 at 12:16 AM. |
Re: how to fix rear blazer windows
fail..
use the IMG codes bud :P |
SK Whut !?!
let me know how you think i did on the write up. i think its pretty decent
and i fixed that as i posted it.. im like f*ck wrong code |
came out good. I need to replace my rear windows and I will be smoothing and painting them when I do.
*SMACK* that ass
damn that shit looks good. but i like first gens because i don't have to worry about that.
Hot Sauce
Nice write-up man. And damn that blazer is straight lifted in the rear! lol
The Dreamsicle
nice. painted trim looks soooo clean on blazers, cant wait till mine is done. i got most of mine repaired by da'ing with 220 and then priming. mine wasnt as bad as yours.
This is doo doo baby!
yep, pretty much exactly what I did with mine, except I didn't take the whole window out
SK Whut !?!
thanks guys... ill post pictures when the blazer is completely done.
I might start on mine then and have them smooth for SES in a couple weeks.
that makes me wish my truck wasnt black. it looks sick
