How I fixed my cutting out/stumbling/missing on my '99 Blazer - S-10 Forum
post #1 of 17 Old 12-08-2011, 04:26 PM Thread Starter
User is: ruyd153 is offline
With the guidance of my childhood friend who has been a mechanic for about 40 yrs., I was able to fix my 1999 S-10 Blazer 4.3L problem. I've got 160K on my SUV. The symptoms were 1) Only after the engine was warm it would cut-out intermittently for a micro-second, it would miss intermittently or stumble intermittently. There was no pattern to the problem : whether accelerating or coasting & NO CODES being generated. Like 99% of Blazer owners, I changed fuel filter,air filter , cleaned the EGR valve and sprayed water on spk. plg. wiring to check for breaks in them w/ no real improvement. It had been exactly 60K since last tune up so I installed new dist. cap, rotor,wiring & spk. plgs.....Still no change in symptoms.. I called my friend Frank, he told me to disconnect the EGR valve & drive it X 15 -20 min. & report back findings . It improved very little. Frank then had me re-connect EGR valve & disconnect the mass air flow sensor & drive x 15-20 min. Voila!! All symptoms disappeared!!!!! The MIL lit up this time. I replaced the mass air flow sensor(Only new not reman. O.E.M. AC Delco per Frank's instructions). It cost me $ 236.00 out the door @ Full Service Co. in San Antonio,Tx.). BTW I did find a new one online for $111.0 before shipping but I don't have the time to wait for it. It's been 4 days now & SUV runs like a champ. I also found a great website to help w/ diagnostics...."http://easyautodiagnostics.com/" R.A. D.
ruyd153 is offline
post #2 of 17 Old 12-08-2011, 05:08 PM
dt99sls's Avatar
User is: dt99sls is offline
Re: How I fixed my cutting out/stumbling/missing on my '99 Blazer
I'm having the same problem with my 99 sonoma. I will try this and see if it helps.
Thanks for posting how you fixed the problem.
1999 Sonoma SLS stepside extended cab zq8.
4.3l auto, magnaflow muffler with polished stainless tip. Soft tonneau cover, window visors, color matched grille.
1999 Jimmy SLS 2 door 4wd. 4.3 auto, g80 locking rear, thrush muffler, 1995 s10 2wd wheels, soon to be bedlinered from the bottom of the doors down and fenders/bumpers and baja bumper bar.
__________________________________
dt99sls is offline
post #3 of 17 Old 12-08-2011, 08:04 PM
Blazin' in Belize
dna59's Avatar
User is: dna59 is offline
Send a message via MSN to dna59
i'm having the same problem...gonna try this
'00 Chevy Blazer 2DR
dna59 is offline
post #4 of 17 Old 12-08-2011, 09:20 PM
Blazin' in Belize
dna59's Avatar
Just unplugged mine and it doesn't feel laggy in the low end again. Where did u find the one for 110?
dna59 is offline
post #5 of 17 Old 12-09-2011, 12:19 PM
dt99sls's Avatar
^ The same thing happened to me. I have been looking around online for one.
Auto parts warehouse has some.
http://www.autopartswarehouse.com/se...0Flow%20Sensor
I called a local parts store that I usually buy from and they want $286 for the sensor.
RockAuto has a delphi mass air flow sensor for $109.34.
There is a 5% discount code for RockAuto you can use on it too.
http://www.s10forum.com/forum/f279/r...1/#post7643904
dt99sls is offline
post #6 of 17 Old 12-09-2011, 12:49 PM
User is: mrmint69 is offline
I have been cleaning my every once in a while on all my vehicles. Using the special spray for electrical. Has anyone tried cleaning theres before replacing?
mrmint69 is offline
post #7 of 17 Old 12-09-2011, 06:48 PM
dt99sls's Avatar
I haven't ordered the sensor. I will look into cleaning it.
dt99sls is offline
post #8 of 17 Old 12-09-2011, 06:55 PM
Blazin' in Belize
dna59's Avatar
I visited the link the OP posted. I read the how to clean the maf section. I had no idea the two ends could come off the actual maf. I took those off and found it was still dirty despite "cleaning" it twice before. Used almost a whole can of electrical cleaner on it until the "hot wires" looked new. Now it has its BALLS back!
dna59 is offline
post #9 of 17 Old 12-09-2011, 07:29 PM
dt99sls's Avatar
Thanks for the info. I will have to check that out. Hopefully it will work for me too. I didn't have any codes for it before I unplugged it.
dt99sls is offline
post #10 of 17 Old 12-09-2011, 07:40 PM
Blazin' in Belize
dna59's Avatar
Neither did I. I just knew something was wrong but didn't have time nor money to troubleshoot. Today is the first time in a while I enjoyed driving my truck.
dna59 is offline
post #11 of 17 Old 12-09-2011, 11:09 PM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
I have to say, I want to vote this guy for BEST FIRST POST EVER!
I too will try this. tomorrow.
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #12 of 17 Old 12-11-2011, 10:02 AM
jgwone21two's Avatar
User is: jgwone21two is offline
Send a message via Yahoo to jgwone21two
Lightbulb Re: How I fixed my cutting out/stumbling/missing on my '99 Blazer
Id 2nd that,
2002 blazer 2dr 2wd 97 rear bumper.3/4 drop,Poly Bushings all around,ZR1 [4]17X9.5,Jimmy SLS front end, future plans a s/c when the L35V6 blows up,L31V8.
post #13 of 17 Old 12-11-2011, 06:43 PM
jminucci's Avatar
User is: jminucci is offline
i tryed this today and it didnt work at all my truck still runs the same as before i did this test
jminucci is offline
post #14 of 17 Old 12-11-2011, 08:52 PM Thread Starter
Just google the part. I think it was on Amazon or gmpartsdirect.com.
BTW -12/11/2011...... Follow-up to How I fixed my cutting out/stumbling/missing(Dec.2011) Yesterday the SUV starting acting up again w/ same symptoms but markedly less severe. This morning I started the SUV up (about 46 Degrees)..started right up & it idled for about 30 secs. & died. I started it up again & began moving wires/ connectors around & when I wiggled the coil wires I saw a spark between the to wires as they enter the coil connector. I shut down the engine & removed the connector, un-twisted the wire ,separated them away from each other & coated them w/ contact cement to insulate them. I drove the SUV all day & never had a hiccup. I guess that was the original problem? or that along w/ a bad MAF. Anyway..Happy it's all fixed!!! I write this so if anyone has this kind of problem ,they can check the coil wires for shorting. R.A.D.
ruyd153 is offline
post #15 of 17 Old 12-11-2011, 08:54 PM Thread Starter
ruyd153 is offline
post #16 of 17 Old 12-11-2011, 09:06 PM
love to work on my truck
Jons1995s10's Avatar
User is: Jons1995s10 is offline
i use a spray bottle to mist the wires if it starts looking like fireworks i replace the wires
1995 S10 LS 4.3 vortec 136k 1" block on back front stock, 4 wheel disc brakes gt4/g80 rear diff
2000 Blazer LT 4.3 Vortec
2001 Chev Silverado 4.8 Vortec 2wd 47K miles Wicked Flow exhaust K&N cold air intake moon visor
Keep on Minitruckin'
post #17 of 17 Old 12-13-2011, 08:11 AM
Blazin' in Belize
dna59's Avatar
^neat trick...i gotta remember that
dna59 is offline
