How can I unbolt exhaust?
Old 07-30-2007, 06:53 PM   #1
Trying to get the exhaust off of the manifold... I have the body off so the bolt is easy to get to..
But I can't find the size of the bolts, I've tried everything... 7mm fit it good, then I twisted, it didn't move, and then it started to strip it a little
Old 07-30-2007, 07:09 PM   #2
DeXtreme on 20/22's
Xtreme24's Avatar
Re: How can I unbolt exhaust?
7mm for the exhaust manifold to the y pipe?
Old 07-30-2007, 08:14 PM   #3
workin it !
S10dude's Avatar
i'm not sure what size it is ...but i am sure it's NOT 7mm....
Old 07-30-2007, 08:20 PM   #4
DeXtreme on 20/22's
Xtreme24's Avatar
i haven't even looked but i'm gunna guess its 13mm or 15mm
Old 07-30-2007, 08:56 PM   #5
PickWick31337's Avatar
or 14 mm
Old 07-30-2007, 09:22 PM   #6
no longer has a 95
95 S_Trucker's Avatar
I did the collector gaskets on my truck. The original nuts were 13 mm. I got new studs and nuts and springs because I broke some of them. The new hardware was 9/16.
Dont be surprised if you break some studs.
Old 07-31-2007, 12:41 AM   #7
I'm talking about y pipe to exhaust manifold... might just be easier to take the whole damn manifold off?
Old 07-31-2007, 01:06 AM   #8
94 Noma, 95 Jimmy
yourname's Avatar
i thought it was like 14mm or 9/16
Old 07-31-2007, 05:35 PM   #9
no longer has a 95
So was I. The collector gaskets are the gaskets in between the y-pipe and the manifold.
I wouldnt take off the manifold. just soak it good with penetrating oil and use a 6 point socket. you might wanna buy a hardened socket because I broke two sockets trying to get mine out because they werent hardened
Old 07-31-2007, 05:45 PM   #10
NTBSSHEVN
NCHEVYHEVN's Avatar
Just about all new GM bolts are 7mm, 8mm, 10mm, 13mm, 15mm, 18mm.
They don't really use 14mm from what I've seen anymore. Just on the old crap.
And I don't think your turning the right peice. I think those bolts actually have little springs on them or something like that I thought. Should be a 13mm or a 15mm.
Old 08-01-2007, 02:56 PM   #11
This is where I'm trying to unbolt it...
Old 08-01-2007, 05:34 PM   #12
The Dreamsicle
cpolaris502's Avatar
just like all of them said, spray some good penetrating oil on there and try breaking it loose after a good soak. its probably 13-15mm
Old 08-01-2007, 05:36 PM   #13
NTBSSHEVN
NCHEVYHEVN's Avatar
Your trying to turn the wrong thing. You need to turn the nut. The nut may come off or the whole stud may come out.
Old 08-01-2007, 06:05 PM   #14
Starting from scratch...
02_Black_XBlazer's Avatar
Put a 3/8" or 1/2" drive ratchet with the appropriate socket on the nut, then get yourself a piece of conduit or steel tubing over the end, as long as you can make fit in tight confines, and use the bar as leverage.
Once you've already heeded everyone else's advice about a good soak with some penetrant of your choosing, that is.
Old 08-02-2007, 10:11 AM   #15
I didn't even notice there were nuts on it... I am blind!
Thanks guys. It was a 15. Took me two seconds, only one of them was a PITA
Old 08-02-2007, 06:22 PM   #16
Molon Labe
BudRacing's Avatar
LOL. It happens to the best of us
Page generated in 0.59036 seconds with 31 queries
[Output: 88.84 Kb. compressed to 82.23 Kb. by saving 6.61 Kb. (7.44%)]
