help w/ 4wd
I have a 2000 Jimmy,that wants to keep jumping into 4-lo,when it goes into 4-lo its very hard to get into 2-hi,I have to push bottons repeadily to get it to change, then when it does it wants to go right back into 4-lo, then the shit lever sometimes will not come out of park, the service 4 wd idiot light came on only 1 time while i was driving,and that was after i had the problem any ideas????
Re: help w/ 4wd
3 or 4 button switch?
After having 4wd problems with one of the vehicles I was working on and looking up info, the switches do go bad and it seems common. If you do some searching you'll find a testing procedure for the 4wd switches. Kind of vague with the numbers but if you have two side by side the numbers should be identical. |
Re: help w/ 4wd
Its a 4 button switch and whear did you look for info please help
Re: help w/ 4wd
it was the switch, changed it and everything is cool
Has Training Wheels
Re: help w/ 4wd
the switches love to fail and stop working or work halfway.
when i bought my 4x4 2000 jimmy, the light stayed on, shortly after buying it, the light went off, but i never noticed till awhile back.. i have to slap the switch multiple times till it lights up then i can switch. |
