help 95 blazer 4.3l fuel pressure problem - S-10 Forum
post #1 of 14 Old 01-03-2012, 09:48 PM Thread Starter
User is: SBD-Spider is offline
I need some help. I have a 95 Blazer 4.3l and it wont start. It starts with starter fluid but then die's. I hooked up a fuel pressure gauge and it goes to 62 psi then decreases to 30 and stays there. I replaced the Fuel pressure regulator, it was bad. put it all back together and still the same thing. I looked for leaks and gas draining out but nothing.
Is there some kind of relay or some thing or what is happening
post #2 of 14 Old 01-03-2012, 11:00 PM
goin broke but n style
S15vortecpwr's Avatar
Re: help 95 blazer 4.3l fuel pressure problem
you need a fuel pump. my 94 did that right b4 it died.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #3 of 14 Old 01-04-2012, 07:22 PM Thread Starter
sweet, I will look at the pump. Hopefully thats the problem.
post #4 of 14 Old 01-04-2012, 08:03 PM
User is: paul bell is offline
Silly question but did you change the fuel filter?
LS1tech.com Firebird forum moderator-how may I help you?
1971 Monte Carlo SS-496, 600 HP, 600 FT-LBS
1999 Trans Am
2003 Chevy Blazer, 4DR, 4WD
post #5 of 14 Old 01-04-2012, 09:47 PM
Extended cab or no cab.
cpolaris502's Avatar
User is: cpolaris502 is offline
It depends on where the pressures are at at which point of the starting I would say.
It should be right around 58psi while priming and running. It will drop some while cranking. How long does it take to go down to 30?
Cory - TWISTED KONCEPTS
1999 2dr Blazer-Bagged and V8'd {Build Thread}
2005 Silverado 2wd 4/6'd. 402ci LSx/4L80e/turbo 780whp/680tq, 17psi boost---- Build Thread
1982 2wd Chevy C30 Crewcab Dually, 454/Manual
2002 Audi A4 1.8T Quattro.
post #6 of 14 Old 01-05-2012, 10:36 AM
Goran's Avatar
User is: Goran is offline
check the fuel filter first...
Cheers
Goran is offline
post #7 of 14 Old 01-06-2012, 05:32 PM
User is: mrmint69 is offline
I change my fuel filter every 25K miles. If you have more than that, its time even if it isn't the problem.
mrmint69 is offline
post #8 of 14 Old 01-25-2012, 05:28 PM Thread Starter
The fuel filter is new, I checked the psi right before the fuel filter and it said around 75 - 80 psi, but doesn't decrease at all. Then I checked at the fuel psi check spot behind the manafold and it is saying around 50 then drops to 30 pretty fast. I have the manafold taken off right now and it looks dry but crudded up tho. I checked the voltage at the spider line connector and it is giving me .54 vdc is that correct or totally wrong? I have replaced the FPR, the old one was bad. But Now I am lost at what could be the problem.
post #9 of 14 Old 01-25-2012, 06:25 PM Thread Starter
I went and tightened all i could and now it only decresses to 45 psi and stays there. Could the o rings be bad or could it be a pin preak leak that stops leaking at 45 psi?
post #10 of 14 Old 01-26-2012, 07:30 PM Thread Starter
I took off the fuel line that is going into the fuel injector spider line, It is giving me 75 - 80 psi. Is the spider line bad? I have replaced the FPR already, did I put it on wrong?
post #11 of 14 Old 01-26-2012, 11:08 PM
could be a bad new pressure regulator.
post #12 of 14 Old 01-29-2012, 03:58 AM Thread Starter
I have replaced the whole spider assy from one i got from a junk yard, it pushes to 60psi then in 2 sec drops to 55 psi and stays there. Then I replaced the FPR on that one and it still does the same thing, it hits 60 psi then drops to 55 in like 2 sec. WTF I am lost. I also put it all back together and spreyed starter fluid into the air intake and it started then blew a fire ball out it and almost got my face. I have never had some thing like that happen, What is wrong that it shot a fire ball at me lol.
post #13 of 14 Old 01-29-2012, 04:43 AM
AWD V8's Avatar
User is: AWD V8 is online now
That fuel pressure behavior is correct, the fireball is not!
If you get backfires/flames then most likely you have the firing order or plug wires wrong. It is firing a plug while an intake valve is still open.
Recheck the firing order on the cap.
Possible that you have valve problems, I'd check compression too. A burnt/sticking intake valve will let the combustion back into the intake.
post #14 of 14 Old 01-29-2012, 11:16 AM
I agree. It looks like you're getting there as the pressure looks normal now but the firing order sounds off. Go over everything again slowly, carefully...
1999 Trans Am
