Not Low Enough
Heater Core Failure??
I got a 2001 4dr blazer and i think the heater core went bad. Has anyone ever experienced this b4, were is it located at and how hard is it to replace? any help is greatly appreciated.
Stepsides are Da Shiznit.
Re: Heater Core Failure??
what is it doing is it leaking
Not Low Enough
i'm not exactly positive. i work for a car dealer that sells chevys. i spoke to one of the service advisors and they said most likely its the heater core
I'm probably drunk.
pop the hood and you will see 2 hoses going into the middle of your firewall
take them both off, and put your garden hose in one side...turn it on and water will flow out the other tube repeat this with the hose in the other hole, and do it back and forth a few times then either flush your coolant and put non dexacool brand in or have it flushed and have them put non dexacool antifreeze in my guess is that the dexacrap coolant clogged your heater core...you do not want to replace your heater core as i have head that means removing your dash |
why do you say it is your heater core??do you not have any heat? just do a full cooling system flush and reverse flush and it should be fine also blaz1n is good if you have just your core plugges but i would suggest the whole system flush because the "wonders" of dexcool
Not Low Enough
BLAZ1N...you were exactly right i did that, and it works like a charm. thanks for the help
I'm probably drunk.
no problem buddy
glad i could help as soon as you get a chance get the dexcool coolant out of there they make a "universal" coolant now...i used it and all good so far |
