heat help?
Old 11-17-2008, 08:07 AM   #1
gmcunit99's Avatar
heat help?
i change the thermostat and put new anti-freeze in it and it only works part of the time...any insight in this?
Old 11-17-2008, 10:13 AM   #2
gmcunit99's Avatar
Re: heat help?
bump
Old 11-17-2008, 12:39 PM   #3
Re: heat help?
if you heat only work when your driving and turns cold when you're idle, then it's likely you system isn't bled properly
**** I've just bought my jimmy 2 months ago, so I havn't really worked too much on these cars so I don't know if the cooling system needs to be bled after replacing, but I know that my previous cars this happened so I thought I'd throw it out there
Old 11-17-2008, 12:56 PM   #4
The Dreamsicle
cpolaris502's Avatar
Re: heat help?
You're going to need to give a lot more info to help solve the problem. We dont know when sometimes is, for how long, etc.
Old 11-17-2008, 02:37 PM   #5
gmcunit99's Avatar
Re: heat help?
like it heats up then when high blast it stops and blows cold air
Old 11-18-2008, 07:35 PM   #6
gmcunit99's Avatar
Re: heat help?
anyone?
Old 11-20-2008, 11:52 AM   #7
Registered (Ab) User
Yogi's Avatar
Re: heat help?
HUH?
Old 11-20-2008, 01:46 PM   #8
Re: heat help?
you probley have air in the lines... there is a bleeder valve right above your thermostat... open that up when the engine is cold and then start it... let it sit there till it starts to warm up then close it... what you should have done to begin with is filled the engine up with antifreeze before you put the thermostat on and then finished filling it after it was good and sealed...
Old 11-20-2008, 04:54 PM   #9
gmcunit99's Avatar
Re: heat help?
its not mine its my gf's....
btw i dont see a bleeder vavle
Old 11-20-2008, 06:09 PM   #10
The Dreamsicle
Re: heat help?
in the left side of this picture, right above the rubber hose you can see a square head plug. Directly under the thermostat. It will depend on what year the truck is which you never mentioned. Need more info still. Describe the problem in detail.
Old 11-20-2008, 06:11 PM   #11
I AM CANADIAN
tt85_GM's Avatar
Re: heat help?
or run the engine cold with the rad cap off and keep topping off the coolant, works for me. Heat is amazing.
Old 11-20-2008, 11:04 PM   #12
Wannabe Dragger
ExtCab96S_Dime's Avatar
Re: heat help?
lol Not to whore or hijack, but I replaced my thermostat and I didn't bleed it with that plug or anything. I have heat, but it's nowhere near as hot as my 96 S10, would that maybe be why? Although, it never has a problem with heat being gone all of a sudden or the temp gauge dropping or anything.
Page generated in 0.57799 seconds with 31 queries
[Output: 76.35 Kb. compressed to 71.12 Kb. by saving 5.23 Kb. (6.85%)]
