Heat from vents when heater turned off!?
Old 05-03-2007, 07:50 PM   #1
verbalkint99's Avatar
Hello all! I just just traded my 96 Ram for a 99 Blazer a few weeks ago and figured I should find a forum as well! This here seems to get the most traffic of the ones I have been lerking on so this is where I will renew my Chevy addiction!
Unfortunatly I have to start off with a possible need for repair.
Even though the temp controls are turned off and to the cooldest setting there is still very warm air comming out of the floor vents. Every combination of settings seem to work as intended, other than the Off setting. :/
Any ideas?
Old 05-04-2007, 10:16 AM   #2
Re: Heat from vents when heater turned off!?
Sure it's coming from the vents and not from the firewall? Just a guess
Old 05-04-2007, 10:32 AM   #3
slow progress
pimkins's Avatar
welcome to the s10's / blazers. there was a how to to fix it a while back but might of been erased with the server crashed. they all do it. when its how i put the control to the defrost and open the windows so my feet aren't in a sauna. i think the how to was to plug something behind the glove box. ill try searching to help ya out.
Old 05-04-2007, 10:42 AM   #4
slow progress
pimkins's Avatar
alright couldnt find the actual thread on the fix but what others have said...
Quote: Originally Posted by orangesonoma
open the glove box and push small metal clip up and lower glove box and remove the gray vacuum line...you will hear air push out...stop it up with a vacuum cap and your all set...
people call it a "hot foot fix"
and this too
Quote: Originally Posted by chvys10
grey line behind the glove box. when u unplug it you will hear a vacume niose from the line.. just put a screw in it, and u ill get clod air.
downfall: ... when its cold it will take the truck a few min to get warm air out of the vents.
they both say the same thing just different ideas on how to plug it, Good Luck
Old 05-04-2007, 10:45 AM   #5
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Good find
Old 05-04-2007, 10:50 AM   #6
&amp;amp;lt;3 redheads
556mm's Avatar
rated ya up pimkins.
Old 05-04-2007, 01:47 PM   #7
Yes, good find
Old 05-04-2007, 06:20 PM   #8
Interesting, thanks!! I will try that after work today. Seems easy enough to be able to do each spring and replace it in the fall.
Old 05-07-2007, 12:20 AM   #9
JMew03's Avatar
stupid chevys
Page generated in 0.57278 seconds with 31 queries
[Output: 67.50 Kb. compressed to 63.40 Kb. by saving 4.11 Kb. (6.08%)]
