Having trouble with Idler arm removal
I cracked the nut loose, but now the shaft just spins so I can't get the nut off. I used a pickle fork to seperate the idler from the relay bar.
How do I hold the post still so I can get the nut off? The book said I would need a puller, but I don't see how a puller would help. The fork did the job of the puller. Any ideas? |
Local Tech
Re: Having trouble with Idler arm removal
it really helps if u have an impact gun..... is there a hex key hole in the end like the full sizes?
No impact gun.
No hex key hole at the nut end. I'm pretty sure the other end is sealed. |
Local Tech
The two bolts are still in the frame.
The bolt with the castle nut that attaches to the relay bar is what I am talking about. I broke the nut loose and now it is spinning with the nut. I don't see anywhere to get a hold of it to vise grip it. I tried to pound the pickle fork in to put tension on it again, but the fork just pushes out. I may have to get out the Dremel and remove the nut sideways. I also thought about cutting a slot in the screw head and using a big flat head to hold it. However I can't really get a wrench on it, I have to use a socket. |
Oh, it's 4wd. 97 Jimmy
Slap my meat on your pita
You tried puttin pressure between the centerlink and the idler arm and then trying? You may need two poeple. Otherwise it looks like your gonna hafto cut that bitch off.
Local Tech
what i meant was vise grip the top of the idler arm to the center link.... if you put enough pressure on it, itll stop spinning
Registered (Ab) User
Can you retighten the nut and get the taper to reseat, just a little? If you can get the taper to hold it, then you could back the nut off and then give the bolt a whack to get it out of the taper.
I am going to have another try at on sunday. I may hafta cut it if I can't get it to sit still.
I used a big C clamp and it was cake after that.
Thanks |
