The Bowtie Brigade
gurgling sound in the dash...
Ok. I bought a '00 4 door 4wd Blazer when I bagged my S-10 so I could have something to drive to work and all when its nasty out, but, there's this "gurgling" sound when my Blazer is in drive or reverse. It stops when I put it in nuetral. And it gets louder when I give it some gas. The transmission has been replaced by a previous owner, so does anyone think it may a vacuum line? It shifts fine and doesn't leak. Are there some vacuum lines or something that may have been left off? Any help would be awesome.
Thanks. |
Re: gurgling sound in the dash...
check the coolant level, you're probably low. The gurgling is the coolant going thru the heater core |
Mcfly Minis inc
it's air in the heater core, i think you can purge it out with a hose conected to the coolant lines that go into the fire wall.
It's called the s-10 waterfall. kinda like the chevy lean, it's pretty common. |
Flat Black Chevy
i don't think its just the s-10s because my 98 blazer does it also, but now that i read that you can purge the air out i will try it.
Mcfly Minis inc
thats what I meant. |
forum idiot
The Bowtie Brigade
I flushed the radiator out when I changed antifreeze. It ran for a solid 30 min with a water hose pumping water in the motor. So it can't be air in the core. It still makes the gurgling sound. Anyone else had this problem?
yea coolant sloshing my bravada does it too.. gets pretty annoying |
355 member
The Bowtie Brigade
Its not coming from the heater core. It's from the middle of the dash. I'm still clueless.
I have an '01 Jimmy, and I have a rattling sound coming from my dash. From what I have researched, it might be the cowl that is making the rattling noise. |
FloridaTruckScene.com
I hear the same gurgling sound in my 96 s10 sometimes. I don't use my ac and it still makes the sound so I don't know what it is. I ignore it now.
hahaha, yeah... same here. I have a 96 noma, Ive def heard this noise quite a few times.. I dont think its anything serious, but it can be annoying
i had this and it was my water pump, for awhile i thought the truck was trying to get drunk
TEH
i have the same problem.
Is the air. After some few (5-6) trials I got a better condition in my 95: from waterfall to the sounds of a japanese garden. To improve leave the rad cap off until the thermostat is fully open. Raise the rpms quite a few times. Repeat the cicle after cooling.
Nice to know... I thought it was me one day but it was my truck.... thank god it rarely happens..
My 96 Jimmy did not have the gurgling sound until I changed the FI spider!!! I assume one of the hoses is vibrating. Or the flow of fuel in the hoses is causing the problem.
I just noticed my a week ago. its pissin me off bc everyone who rides w me always says whats that noise??? grrrrr
I get the same question. Add on top of that noise the freaking compressor noise, it annoying. I'm going to try and bleed the air out. The A/C clutch is on it's last leg...11 years!! So I'll run it until it goes kaput.
my gurgling sound turn out to be bad waterpump...truck was overheating
#24 |
I hear mine rt in the morning or as I first start to drive it.
#25 |
my 2000 xtreme 4.3 started doing it this morning right after I had the lower intake gasket and the water pump replaced and the cooling system flushed.
I will be taking it back to the mechanic this weekend to have him look at it cuz cuz I didn't drop $760.00 in repairs to have to put up with this F-ing noise every morning. I'll keep you guy informed as to what he says. But i would have to agree with the air in the system thing. |
#26 |
The Bowtie Brigade
That would be much appreciated. ![]() |
#27 |
well sorry about the delaied responce but he told me to drive it for an week and if it was still doing it to bring it back and he work on it. But sure enough less then a week later it stopped doing it.
#28 |
anyone ever figure this out???
#29 |
SS turbo
i had a similiar problem, so i started looking at the cooling system parts
turns out my rad cap let in air on cool down (gasket went to crap) and my upper rad hose wasnt completely tight on the thermo housing probably letting in air as well. bought a new RAD CAP with the safety release lever and tightened the hose, bled air out of the system by squeezing upper rad hose with the rad cap lever up. Then warmed it up threw the heat on high and did it again, now all air is gone, and wont come back. nice and quiet with no air sounds |
