Fuel Pump help
Old 11-17-2009, 09:34 PM   #1
Learn As You GO
Fuel Pump help
Anyone have a pic of the fuel pump test terminal? Or a good description of where it is? Think the pump is bad again and want to test it. Thansks in advance. I have a 98 4dr 4x4 blazer.
Old 11-17-2009, 09:42 PM   #2
no longer has a 95
95 S_Trucker's Avatar
Re: Fuel Pump help
im not sure where it is on a 98, or if it even has one.
on my 95 it was a single orange wire with a black connector that came out of the wire harness right under the brak booster
another thing you could do is jumper the terminals at the fuel pump relay
Old 11-17-2009, 09:50 PM   #3
Learn As You GO
Re: Fuel Pump help
Also anyone buy just the pump? not the whole module. Anyone know where you could get it besides ebay?
Old 11-17-2009, 09:50 PM   #4
Learn As You GO
Re: Fuel Pump help
which one would i jump?
Old 11-17-2009, 09:58 PM   #5
no longer has a 95
Re: Fuel Pump help
look at the diagram of the relay, i cant remeber if its a 5 terminal of a 4, but jump the load side, not the control side, but do it with a pretty good sized jumper
Old 11-17-2009, 10:23 PM   #6
Move over here I come
89S10WBlazer's Avatar
Re: Fuel Pump help
ebay is the only place you can get just the pump and I do not recommend buying just the pump. Better off getting the whole module. Went through the hassel of buying the pump, never again. Went out in three months. You can pick up a new pump just by looking around for about 160. Try Rock Auto and Van Senus, not sure if ven senus delievers though. I got mine from Van Senus. vansenus.com
