Fuel Gauge Craziness
Old 10-04-2009, 10:27 AM   #1
Hater
My aunt has a 2000 Jimmy that's been having starting problems. After a dead battery they jumped it and the fuel gauge needle now points towards the floor board. It sat in their garage for a few weeks unable to start and then the other day it started up but the gauge is still all jacked up. Any ideas? I was thinking fuel pump or they fried something when they jumped it.
Thanks
Terry
Old 10-04-2009, 01:23 PM   #2
The Dreamsicle
cpolaris502's Avatar
Re: Fuel Gauge Craziness
It's hard to say if it just started happening after they jumped it, but with these trucks it is very common for the sending unit to go bad and cause the gas gauge not to work. but with how you described when it happened, its hard to say it is the pump.
Old 10-04-2009, 01:38 PM   #3
Hater
I was thinking fuel pump when they first started having the starting issues. We put a new filter on it and it seemed to help for a bit but it was only a temp fix. The filter was pretty nasty when we pulled it off so I was thinking the strainer was prob full of crap then they jumped it and all hell broke loose.
There is pressure at the check valve on the fuel rail, and the pump does run when the key is turned on, but I don't have a fuel pressure gauge to check just how much pressure there is. Since the pump and sender are only available as a complete assembly I was thinking/hoping the problems were related and the fact that it happened after the jump was just a coincidence.
Thanks for the reply.
Terry
Edit: I was just told that it had done it a few times before the jump start but lined out after a few fill ups. Sounding more and more like a pump/sender to me. Any thoughts?
Old 10-04-2009, 01:54 PM   #4
Hater
Ok, little more info. They've been driving it for the past week or so and it starts and runs fine unless it sits more than a day.
Old 10-04-2009, 02:30 PM   #5
The Dreamsicle
Ok, thats a good sign then. i dont want to tell you the fuel pump will fix the gauge though but it is a good chance, it could be anything.
On the starting issue... try turnign the key on before starting it so that the fuel pump primes. My bravada is acting the same way right now, not starting right away after it sits for a while. if i let the pump prime before I crank it it starts right away. But if i just hop in and try to start it, it takes about 5 seconds of cranking before it will go. I put in a new fuel pressure regulator last week after seeing that that was a common problem but it didnt fix the issue for me. My next thing to try is either the spider injector or fuel pump, but my gas gauge is also screwed up so i might put in a fuel pump anyway and hope that it fixes both of my problems.
if you can get a hold of a pressure gauge, let us know the results.
Old 10-04-2009, 02:46 PM   #6
Hater
If they decide on a pump I'm doing a new filter and pressure regulator just for kicks. I really hope it's not the spider, those bastards are expensive even with my discount. Plus, I've been told they're rather involved, and I really don't want to get into all that.
Will let you know the pressure situation when I get to check it.
Old 10-04-2009, 07:55 PM   #7
The Dreamsicle
The regulator is just as involved as the spider. The regualtor mounts in it. And as far as i know, when I was chasing a fuel issue in my blazer 2 months ago, the spider and pump are about the same price, you're lucky you get a discount though.
And heres some pictures of when I did the regulator in my bravada last week.
I took the injector out, the FPR is right on the back of it.
Page generated in 0.56250 seconds with 31 queries
[Output: 61.36 Kb. compressed to 57.97 Kb. by saving 3.40 Kb. (5.54%)]
