Front Wheel Hub Replacement for 2WD
Old 03-26-2008, 10:20 AM   #1
I had new tires put on yesterday and the shop said they couldn't align my '99 Blazer because I had a bad front hub. To demonstrate, the mechanic rattled the wheel back and forth slightly. How can one tell the hub is bad versus a rim?
I assume this isn't uncommon with 114K on the odometer?
How hard is this to replace yourself? Any info would be appreciated.
Thanks,
Rick
Old 03-26-2008, 10:39 AM   #2
Ted's emporium.
blazerman's Avatar
Re: Front Wheel Hub Replacement for 2WD
jack truck up,put one hand on top of tire and other hand on bottom,then shake,if it has play then you need a hub,it its the way the guy did then that usually means tie rods.the hub is easy,take off caliper,rotor,there will be 3 bolts that hold the hub on,i think its 3 if im wrong somebody correct me,unplug abs sen then reinstall.with that mileage you probaly need one.
Old 03-27-2008, 09:53 PM   #3
Thank you for the response. I jacked the Blazer up again last night and with my hands in the 12 and 6 o'clock position, its definitely the hub. I may end up needing to replace two. Not what I wanted to hear, but with high mileage there is definitely going to be some maintenance.
Thanks again,
Rick
Old 03-27-2008, 09:58 PM   #4
goin broke but n style
S15vortecpwr's Avatar
r u sure it is a hub and not balljoint
Old 03-27-2008, 10:17 PM   #5
www.oaktowntrucks.com
draginlow's Avatar
i did both of mine at 45,000 but i have large rims
they are not to bad just 3 bolts and a abs wire after you pull the brakes
a say 1 hr a side and that thinking you have some rust
and get a good set "and yes they are not cheap"
even if the cheap ones have a life time replacemt...thay may leave you on the side of the road
just something to think about
Old 03-27-2008, 10:25 PM   #6
How can I check to verify its not a ball joint? Everyone has been saying hub since when I jacked it up and pushed back and forth in a 12 and 6 o'clock position, it moves.
I really appreciate all the comments.
Thanks,
Rick
Old 03-27-2008, 10:55 PM   #7
draginlow's Avatar
the bast way to find a bad ball joint is jake up the blazer and put a jack stand under the lower control arms and let the car down but the wheels are off the ground
then take a prybar and pry the spindle back and thorth or have a buddy move it for you, you can see it moveing if it's bad and or you will see the hub bad
and i had to do my lower ball joint at 60,000 on the driver side
Old 03-27-2008, 11:27 PM   #8
Ted's emporium.
blazerman's Avatar
most likely its the hub,i work at a delco dealer but i got hubs from a company called bca.exact same hub as a delco just cheaper
Old 03-28-2008, 10:01 AM   #9
Again, all the comments are much appreciated. Will probably tackle this project tomorrow.
Thanks,
Rick
Old 03-29-2008, 12:25 AM   #10
Any tips for getting a rusted rotor off? I'm into the hug replacement job and can't get the rotor off. I don't want to pound on the dust shield so its limiting my ability to pound on the rotor with a rubber mallet.
Old 03-29-2008, 02:39 AM   #11
Ted's emporium.
blazerman's Avatar
wd 40.,oak the hell outta it.then hit with it a hammer on the part around the wheel studs.
Old 03-29-2008, 11:26 AM   #12
Are you using a rubber mallet or metal hammer? Don't want to damage the rotor but this is getting pretty frustrating.
Old 03-29-2008, 03:20 PM   #13
Plan B is to take the whole hub off and replace the rotor with a new rotor on the new hub.
Is the dust shield located behind the hub? If its between the hub and rotor, then that would be a problem.
Old 03-29-2008, 04:01 PM   #14
draginlow's Avatar
i use a air hammer around were the studs are after hitting them with pb blaster to brake them lose
but a metal hammer is ok on the back side to brake them lose just keep turning the rotor and work your way around
Old 03-30-2008, 01:42 PM   #15
Ted's emporium.
blazerman's Avatar
yeah, i use a metel hammer.i think its a 5-6 lbs.and the dust shield is mounted between the hub and spindle.but i dont think you can get the brake rotor and hub off in 1 piece.if you have to hit the rotor from the back side put a small piece of wood between the hammer and rotor and the keep turn it after each hit.
Old 03-31-2008, 12:09 AM   #16
Well, I ended up pulling off the hub and just buying a new rotor. It was the OEM rotor and I'm not sure it had ever been off (will have to measure thickness to get an idea).
I appreciate all the responses.
Old 03-31-2008, 10:52 AM   #17
Joelin's Avatar
Can anybody tell me how to change front brake rotor of my 2000 S10 Extreme 6V 4.3L and what its the best rotor?
I try to safe some M$$$$
Page generated in 0.59759 seconds with 31 queries
[Output: 92.98 Kb. compressed to 86.08 Kb. by saving 6.90 Kb. (7.42%)]
