Front wheel bearing on a 4WD
Hi,
I got a noise around my front right wheel, especially on left curves when there's lots of pressure on it. I suspect a used / worn wheel bearing. I never replaced a wheel bearing on a 4WD and I cannot figure out in the part list what part I should change in this case. Is the Axle Shaft Bearing (outer I guess) the culprit or both inner/outer? Or should I change the whole Hub assembly with axle bearing. As my vehicle is not imported here, is there an easy way to diagnostic what's going on? Thanks in advance for your help |
Re: Front wheel bearing on a 4WD
on a 4wheel drive you have to replace the bearing hub. no way to replace the bearings only
Thanks for your help, even if the price of a front hub itself is a bad news compare to a single bearing!
around here in iowa it will run you around $108.00 for the hub
ebay.com... find a seller that ships internationally.. it will still be cheaper then paying for it in france...
Newb
im having the same problems now...ugh.
Junk yards
![]() Just did one last year now the other side is doing exactly what you mentioned, Got mine for $50 on ebay new. (3) 18mm bolts hold it in plus the large axle nut. |
forum idiot
cant wait to do it a third time!! |
Overhead Console Expert
they arent real hard...just time consuming. the biggest pita it the 3 bolts...i could only get to them with a wrench...it took a while
why didnt you use a socket instead of a wrench?
it wouldnt fit with the cv shafts in the way
Buy the bearings from synergyoffroad.com Guys have had great results with them. They runn just 100.00, are made is the USA here in MI...
