Front End Work - What to change
Old 10-15-2009, 01:02 PM   #1
Goran's Avatar
I've got enough Mileage on the Envoy and think its time to do the front end...
It squeaks constantly even after greasing, it's making solid hitting sounds (steel on steel) and the passenger tire is wearing excessively on the outside edge...
What should i change/replace?
THanks
Old 10-15-2009, 10:16 PM   #2
Re: Front End Work - What to change
It can be a combination of several things like tie rods,ball joints,idler arm,pitman arm,shocks,wheel alignment. These are all things that can contribute to your problem.
Old 10-15-2009, 10:56 PM   #3
Dain Bramaged
There are no set mileage standards for replacing worn front suspension parts. If you like spending money, change it all and be done with it. Otherwise, take it to a competent alignment shop and they will tell you what is worn.
Old 10-19-2009, 10:49 AM   #4
iroc2nv's Avatar
I agree with b1lk1, take it to a alignment shop
Old 10-19-2009, 12:51 PM   #5
AE86 SR5's Avatar
As for the squeaking, my controll arm bushing are dry rotted I spray them with white lithium grease.
