front end wheel bearings
Old 06-27-2007, 10:51 PM   #1
purevil115's Avatar
my front end is making a howling sound when going down the highway above 50 or so and it keeps going unless I turn right, it seems to be coming from the drivers side would this most likel;y be the wheel bearing. Also when I turn right going less than 20 mph, it clanks like a ball joint it bad but there not there newer, any ideas if this could be the bearing too.
Old 06-27-2007, 10:52 PM   #2
purevil115's Avatar
Re: front end wheel bearings
its a 4wd blazer by the way
Old 06-27-2007, 10:55 PM   #3
forum idiot
orangesonoma's Avatar
sounds like my blazer...changed out the bearings and bam...no more noise...
Old 06-27-2007, 11:38 PM   #4
purevil115's Avatar
what can I do to make sure this is what it is, cause there xpensive
Old 06-28-2007, 01:07 AM   #5
Canadian Dictatorship
Holeshot's Avatar
Without a doubt that is the problem.
You can take off the wheel and see how much play it has by grabbing it with both hands.
Like I said though - it is for utter certiainty the hub bearing assembly.
You're looking at a having to buy a new. I was able to pay a shade under 200 (canadian) for a brand new one.
Both of mine have had to be changed in the front. It's just an extremely weak point with our vehicles. :shrug:
Old 06-28-2007, 01:11 AM   #6
forum idiot
200?? whats that in us?
Old 06-29-2007, 12:36 AM   #7
Holeshot's Avatar
I'm happy to say that our currency is nearly at a PAR with your's lately!
I'm sure we'll be passing the almighty US dollar soon.
Old 06-29-2007, 12:54 AM   #8
forum idiot
so you paid 400 bucks or was it 100 each??
Old 06-29-2007, 07:20 PM   #9
Holeshot's Avatar
Right around 400 in total.
200 a side.
Old 06-30-2007, 11:03 AM   #10
pinnacle's Avatar
be careful. mine had all the same symptoms - but had no play. if you pushed or pulled on the wheel when it was jacked up - it was solid. I replaced both wheel bearings anyway. turned out it was a bearing in my front diff.
it totally sucked.
Old 06-30-2007, 01:13 PM   #11
forum idiot
200 a side.
jesus...you dont want to know what i paid for mine.....
