Well just about 3 days ago, I noticed how badly my truck started pulling to the left when my steering wheel was STRAIGHT. I have to turn my wheel a little to the right to drive straight.
I have a '98 4x4. Just had a front end alignment done about 3k miles ago. I wouldn't think it is out of alignment already. I had new tires put on the same day as the alignment. My right wheel looks funny to me. Hard to explain. Just looks curved inward. Could my control arm or something be messed up? Or is it already out of alignment? The work that was done is under warranty so if it is the alignment, I can get it fixed. I have not any time to go back to the place and have it checked out. Probably will tomorrow if you all can not help me out. Thanks! J Blake |
Re: Front end pull. I'm getting frustrated.
check the tire pressure ? ..
The passenger front wheel seems to curve inward when parked certain ways. Then outward when parked other ways. Chit is driving me crazy. I can't take my hands of the steering wheel without almost swerving. |
First thing i would do is,swap front tires from side to side.Go drive it.If it pulls the other way,you have a bad tire....
if you hit any kind of pothole it could knock it out of alignment
could also try swapping tires with rears jack the truck up and put something close to the tire/wheel and rotate it by hand...if there is wobble either the wheel is loose/not seated correctly, or the lip of the wheel could be bent |
I got nearly ran off the road a few days ago, hit a nasty pothole. Have ran over a few here recently. It seems like everyone is trying to run me off the road.
Possibly out of alignment. I'm going to take it back to the shop tomorrow. Have them rotate and balance my tires also. Any of you all know what size of speakers go in the doors, and in the back of my blazer? Also, what type go in the dash by the windshield? I do not have any there. Sorry, I am to lazy to search. Flame all you want... |
The Dreamsicle
6.5's in the doors. and if its a 2dr, then it has 6x9s in the rear.
You...Tonight
4x6's in the dash i think
Yup. 4x6 dash, 6.5 doors and 6x9 rears. And check ball joints, tie rods and everything else in the front end.
