FLOWIDA STUNTERS
Front Brakes Sticking
95 blazer, front brakes arent backing off after i release the pedal, i replaced the brakes booster, front hoses, calipers, and rotors because it had warped the old ones, and its still doing it, would it be the proportioning valve under the master cylinder? or the master cylinder? or the abs cpu. the abs light is on by the way.
Re: Front Brakes Sticking
go to a shop and have them tell you why the abs light is on first of all, that could be why you are having problems.
GD, that's a lot of work to do to a vehicle when the light is on and you have no idea why. I agree with the above in saying you need to find out why the light is on to make sure you are messing with the right stuff.
abs light on means one of the wheel sensors is shot
abs light means that any abs component is bad, ie speed sensor, wiring, module, air, any of those expensive abs things.
Ticket Magnet
Before you tear into the abs, make sure your hoses ane not collapsing. That will cause your brakes to stick.
