GMC - Professional Grade
Fog Lights
My Blazer has Fogs, and im looking everywhere for Clears that fit my blazer with the fogs, the only company that makes em is APC, and i dont like them. Is there any way to remove the fogs so i can put regular clears on it? Do i need a new grille piece or just take the fogs out?
I'm probably drunk.
Re: Fog Lights
just buy whetever clears you want and install them (im pretty sure they will be the same grille)
take the bulbs out of the fog lights, put a plastic bag over the connections and duct tape over it i dont see why that wouldnt work you could always call the dealer and ask them if the part number is the same for a grille that has fogs, and a grille that doesnt...that way you'd know for sure |
Slap my meat on your pita
Re: Fog Lights
Insane Network Engineer
Re: Fog Lights
You can remove the fogs and existing blinker/park assemblies and replace them with one unit... As stated above, simply seal the old fog light sockets... but the APC's aren't bad at all..
Re: Fog Lights
The clear corners i saw @ apc's site had yeller flecters on the corners and i want ALL clear so im not sure where those fully clear ones in the pics were from, unless the yeller can be removed?
ZR2 member
Re: Fog Lights
Stylinconcepts has the fully clear ones.
Throw some Ds on that Bch
Re: Fog Lights
Do you mean the lights like mine with the fogs in them? I took mine apart and took out the orange in them.
