Finally breaking down and buying a 2nd gen...
Old 03-19-2008, 12:01 AM   #1
Mr. Sparkle
Onimun's Avatar
Hello everyone,
Never posted in this section before, kinda cool here...haha. Anyways the engine blew in my 1st gen Blazer and im looking at a replacement. I really know very little about 2nd gens, so my question is, what should i be looking out for as far as wear items and such in buying a used blazer/s10? There any recalls i should be worried about? Engine problems with these trucks..? post em up.
In particular im looking at this 2002 Blazer 4dr with 63,000 miles, i just want to know what i should look for to make sure it will last a long time. If you have any Input please post up.
Thanks guys!
Old 03-19-2008, 12:08 AM   #2
The way of all flesh
J.Cakes's Avatar
Re: Finally breaking down and buying a 2nd gen...
make sure teh flux capacitor is in working order
ok, since you got your panties in a bunch
just make sure you dont see any leaks or anything, make sure it idles right, and most importantly make sure the ac works great,
Old 03-19-2008, 12:15 AM   #3
Mr. Sparkle
Onimun's Avatar
Yup, theres no leaks. It idles right at 500 Rpm which is quite a change from my 1st gen . The a/c was working alright, didnt experiment with it too much. Ill check that next time. What wear items may i come across with the 4.3? What tends to go bad?
Old 03-19-2008, 02:58 AM   #4
The Dreamsicle
cpolaris502's Avatar
i'd say they are very reliable for the most part. just check over the normal things, fluids and what-not. you could check the stickies at the top of this section and see if any are related to what you're looking for.
Old 03-19-2008, 03:03 AM   #5
Molon Labe
BudRacing's Avatar
The air injection pumps suck on the years 01 and up. Drill some holes in the cover so water doesn't collect in there and it may last you longer if it's not already full of it. Other than that, it's only little things that go wrong as can be expected. Oh, and Blazer hubs are expensive compared to s10's.
That looks like a nice blazer though.
Old 03-19-2008, 03:39 AM   #6
Mr. Sparkle
Onimun's Avatar
Thanks guys!
Wheres the air injection pump located? SO i can inspect it when i go back on Thursday... The truck is real clean and no rust, so thats good. Ill check out all the stickies and such. Anything else i should be concerned about?
Old 03-19-2008, 11:18 AM   #7
Registered (Ab) User
Yogi's Avatar
Quote: Originally Posted by Onimun
Thanks guys!
I noticed that you're in Cali. You may want to get this TSB on the fuel injection system taken care of, if it hasn't been already:
Looks like a nice one! Hope that it works out for you!
Old 03-19-2008, 04:28 PM   #8
Molon Labe
BudRacing's Avatar
The air injection pump is between the two front frame horns below the radiator. You'll see it best from below. It has lines that run up to the front of the exhaust manifolds.
Old 03-19-2008, 04:42 PM   #9
Mr. Sparkle
Onimun's Avatar
That TSB is very weird, sounds like its a pain in the ass to get them to honor it. Ill print it out and have them check it out. Thanks alot Yogi!!!
And ill look for it Grant. Thanks!
Page generated in 0.57368 seconds with 31 queries
[Output: 69.43 Kb. compressed to 65.23 Kb. by saving 4.20 Kb. (6.04%)]
