Envoy Air Compressor
My Air Compressor isn't working for either the load leveling, or in manual compressor mode, I am looking for a wiring diagram if anyone out there knows what it is it would help me out in finding if it's the compressor, or a relay. Thanks
1998 GMC Jimmy/ Envoy 4x4 4.3 Vin W |
Re: Envoy Air Compressor
Good luck...
could be a bunch of things... Relay, fuse, pump... If your pump burned out, it could be you have a hole in your airbags... causing pump failure... hence replacing your pump will only be a temp fix suncore industries in florida sells replacement rebuilt pumps... I got rid of mine and put in regular shocks... much cheaper again, good luck |
I checked them out, but I really ned the wiring diagram so I can see if it's the relay, or the compressor thats bad.
