engine cutting out
just replaced a clogged fuel filter in my 97 jimmy. but it seems to still have a problem getting fuel. engine starts and idles fine. runs good for a couple mins.
but when i give her a little throttle it cuts out/ spits and sputters like the filter is clogged againcheck engine light just started flashing and stayed on seems to be getting progressively worse, fuel pump is only about a year old but it is an aftermarket and has a differant whine to it now any suggestions? |
First Team
Re: engine cutting out
fuel pump.
What is the fuel pressure?
I sure hope your tank is empty before you have to drop it to replace the pump.
havnt checked the pressure yet but i got the tools to handle the 3/4 tank i got
s10 newb
get the code read and tell us what it is. While it very well may be the pump....it may not be.
its got a couple codes
maf low input map high circuit 02 low voltage pending random missfire then i cleared them and took her down the road and a mile later i got a misfire in cyl. 3 |
just tried to pull the #3 plug or the a--hole plug as i like to call it and i broke the plug right in half and my tools r stuck now guess ill have to wait for the weekend
s10 newb
doesn't sound like a fuel pump. Any one of those things could be the problem, however im leaning towards the MAP sensor only because a fualty MAF and O2 sensor aren't going to affect engine vacuum. This doesn' t mean that it couldn't be more than one thing. Start testing things.
pull the map sensor off and use a DVOM and vacuum pump to check the map sensor. It may be running fine for several minutes while its on warm up. O2 sensors aren't functioning while the engine is cold as the computer runs in closed loop, im not positive but ithink the maf may work the same way DONT TAKE MY WORD FOR IT, someone please correct me if im wrong, last thing i want is to spread incorrect info, its been a while and this stuff isn't real fresh in my brain. |
ok replaced map sensor and plugs. cap wires rotor all that crap is fairly new even changed the ecm cause i had one laying around but i can barely make it out of the driveway now and it threw a code for a map high voltage and low voltage 02, fuel pump is sounding weird id like to check the pressure maybe i gonna have to break down and buy a gauge
noma94
check your wire harness coming from the firewall on the right side i thought i had a fuel pump problem but it was a bad harness the wires were corroded i had to rewire and it fixed it
ok fixed that problem i put a new fuel pump in it and it drove excellent but then i was in the next county left my girlfriends house and truck just died fuel pump doesnt turn on now no prime nothing
Your God Drives a Dime!
